Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
How to install hose on model5915-900 - Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Read the instructions more carefully. Thanks
Posted on Jun 30, 2009
How do I installa new hose to the mortorized brush head on my shark lift waway
Hi, it's Allie from Crucial Vacuum!
Replacing your Shark Floor Nozzle Hose is very easy. Start by unplugging your unit to avoid any safety hazards. The floor nozzle hose's side that attached to the floor base of your Navigator can easily be pulled away. The other side of the floor nozzle hose has two tabs that can be pushed in while pulling it away from the base.
When installing, connect the floor nozzle hose to the canister first by pressing both side tabs while placing it until it click in its place. Then connect the hose to the floor base.
You can purchase direct your replacement hose and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=NV352
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 10, 2014 | Shark Vacuum. Navigator Lift-Away Bagless...
My home has a central vacuum system hook-up but no vacuum installed. My friend upgraded his central system and gave me his Eureka Mega Boss central vacuum system and the accessories, including the pow
The power head requires 120 Volts. Some hoses have a receptacle in the handle for the power head plug, and the hose has a cord at the wall inlet end that plugs into a receptacle. Some hoses have a plug at the wall inlet end that plugs into a 120Volt receptacle built into the inlet. The hose plugs into this receptacle when you push the hose into the inlet. The power for this built-in receptacle is wired with line voltage when the system is installed.
Apr 15, 2012 | Eureka 1810 Central System Vacuum
I have a S3765 Hoover Wind Tunnel with a crack in the hose close to the cannister. I know wires run through the hose and that there are wire connections on either end of the hose. The replacement hose...
If the vacuum has been maintained properly and runs well it may be worth repairing. The hose is pricey but less than a new vacuum. Many new vacuums today, especially lower priced ones are very poor quality and don't last much longer than a year. It appears by the schematics of your model you can replace just the hose section or the entire hose assembly. Replacing the hose only would require removing the ends of your old hose and installing them on the new hose.
Sep 28, 2017 | Hoover S3670 Bagged Canister Vacuum
I bought a new plastic end piece for the hose but can't get the old one off the hose to change it???
Soak the end of the hose it very hot water to soften the end of the hose. Then insert a screwdiver inside the plastic end piece and flex the end of the hose inward and pull the old end off. To install the new end, bend the end of the hose into a "kidney bean" shape and push the new end on.
Jan 02, 2011 | Kirby G6 Bagged Upright Vacuum
How to replace the flexible hose between the upright and floor modules?
Turn the vacuum on it's side. Pull the power nozzle end out. Unscrew, in a clockwise direction, the hose from the body/tank.
Reverse to install new hose. Screw the hose into the tank, turning counter-clockwise. Place other end into power nozzle. Ensure it's set properly.
Dec 31, 2010 | Electrolux Epic 3500 Vacuum
I have a Dyson which isn't picking up. The tools work normally. All the air ways and filters are clean and not clogged up. What could it be?
So when the Dyson works on the attachment hose, but doesn't work when cleaning the floors, this can be caused by a few things.
The first place you should look is at the bottom plate. Sometimes if the bottom plate is taken off to clean the brushes, it is very easy to install it back on the vacuum the wrong way. Here's pictures of both the wrong way, and the right way to install this plate. What happens is that the bottom plate is actually higher then the brushes, so when cleaning on carpet the brushes don't actually hit the carpet, decreasing the pick up on floors dramatically.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
If you check this part and it is correctly installed on the machine, here's something else that is pretty frequent on Dyson's that would cause the same exact issue you're having:
Possible Problem # 2. Turn the vacuum upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
I know that you said you have checked the clog ports for obstructions and there weren't any, but I'll just paste the picture of both clog ports on the Dyson just in case:
Other things you may want to look for is the length of the actual bristles on the roller brush. The Dyson vacuums use a very cheap, thin bristle on their brushes. The bristles wear down quickly, and need be replaced I would say every 2-3 years, maybe even sooner if you have pets in your home, and vacuum a lot. Here's a picture of the Dyson brush (this is the DC07 model, not sure if this is the model you have) when it's new so that you may compare it.
If none of these suggestions fixed your vacuum, I'd be more then happy to walk you through some more advanced diagnosing. Please just add a comment using the Clarification request form here on Fixya, and let me know which exact model you Dyson have, and if you found anything new while trying these fixes above.
If you did find this repair helpful, please be so kind and rate my repair helpful and/or leave feedback for the repair. This is really what keeps repair professionals like myself keep posting free repair advice on Fixya, and it's really appreciated.
Thanks again,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Vacuums
I have a Hoover steamvac ultra. The handheld hose
If you have installed the hose properly, try to hold your hand over the suction end with the cleaner on to prime the water in the hose. There is no way to dissasemble the hose. You could have a possibility of a few thing that have failed,
1. the pump that feed the hose
2. the valve on the hose end
3. the check valve where you connect te hose to the machine
Also verify that you are dispensing solution to the floor, if so, then the above needs to be checked.
Have it looked at at repair shop for diagnosis
Oct 09, 2009 | Vacuums
Can't find owner's manual. need to use my kirby g4 to inflate an air mattress. help
Remove power head and bag from motor install pig nose attachment on front where powerhead goes install hose on back where bag attaches put inflator tool on hose
Jul 06, 2009 | Kirby Vacuums
I havent used my shampooer for over a year, and i am now having t
These are the parts-Tank,tray,brush roll,brushroll housing,belt,hose,foam screen(small,quarter sized plastic screen)large foam air filter,(should be on the air inlet at tank).
Starting with brushroll,install belt over brushroll,and place brushroll in the trayInstall the brushroll housing over the top of tray..Looking thru the back,turn the belt lifter knob until the hook inside picks up the belt.Raise the height adjuster on the Kirby all the way up.Attach the entire assembly to the front of maching,and lock it on.Now turn the belt lifter clockwise until the belt drops onto shaft.Snap the elbow end of hose to tray.Before attaching the other end of hose to tank,make sure the foam screen is fitted onto the small outlet at tank,then install hose.Note:Sometimes the screen will be in the tank end of hose allready.Without this screen,you wont get foam,only solution.Make sure the foam air filter is installed in the large opening at the tank,or dirt will get into tank,clogging it.Install the tank to the blower side of machine.You should be ready to go.Lower the height adjustment all the way down.
Dec 15, 2008 | Kirby G4 Bagged Upright Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
118 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
