Question about PNY 2GB microSD Memory Card
Computer won't read my card
I have a Sandisk that's 4GB Micro SDHC that came with another card called the adapter and when I put the card into the computer it won't do anything and I can't find it on there anywhere.
    Sergeant:
  • 268 Answers
You must put it into the adapter before putting it in the computer. It has to be converted from micro to standard sd
Posted on Jun 29, 2009
Where do i put it in my lap top
It depends on whether your laptop supports SDHC, microSDHC, or neither.
1. Supports MicroSDHC: check on the manual the position of the MicroSDHC slot.
2. Only supports SDHC: you need to purchase an adapter - essentially a full-size SDHC with a slot where the MicroSDHC goes. Plug the micro card in the adapter, plug the adapter+card into the SDHC slot.
3. Neither: you need to purchase both a micro-to-SDHC adapter and a SDHC-to-USB reader (usually SDHC in supported in most "XYZ-in-1 readers", like Quanta 32-in-1 USB reader - check out "SDHC USB reader" in eBay, for example).
Feb 11, 2010 | SanDisk 4GB microSDHC Memory Card
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
My PC will not recognize my 2GB Micro SD Card
Does the PC recognize the adapter when you place onto the USB port? If not, try another USB port. It should atleast say it has detected hardware, see if it's finding and installing the drivers correctly.
If it's not the adapter, could you reformat the microsd card? Perhaps, it is corrupted? Is this SDHC or SD (what capacity). Older Blackberries do not support SDHC (I believe this is 4gb or above), perhaps this has something to do with it.
I hope this helps,
Bill
Sep 04, 2009 | SanDisk 2GB microSD Memory Card
Transcend not working in comp.
Cards over 2GB are MicroSDHC. Your reader will have to be able to read SDHC in order to read your card. Unfortunately, your reader maybe to old. You probably will need to buy a newer reader capable of reading SDHC cards.
Sep 02, 2009 | SanDisk 4GB Secure Digital High Capacity...
Sandisk 4gb micro SD with adapter is "unreadable"
Certain cameras will not recognize an SD card because it is SDHC. The format was created after the camera. Camera vendors do issue firmeware updates.
Hope it helps.
Aug 27, 2009 | SanDisk 4GB Secure Digital High Capacity...
I have a 4gb sandisk micro sdhc with adapter and the computer freezes when i have it in the sd drive.I have a hp pavilion a1 a1203w. Is there anything i can do?? Please Help
I had a similar problem not long ago. The SD and SDHC standards are different. SD only goes up to 2GB, and SDHC (high capacity) goes higher than 2GB. THe problem is that SD card readers aren't capable of reading SDHC cards, even though the card will physically fit into the card reader slot. When you insert an SDHC card into an SD card reader, the reader attempts to read the format, and locks up the OS while trying. You'll need to get an SDHC card reader and use it separately like through a USB port or something.
May 13, 2009 | Computers & Internet
Micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
Sandisk 4gb microSdhc wont read in computer
few computers nowadays read SDHC out of the box. you will need to purchase a SDHC reader that plugs into your USB port.
May 12, 2008 | SanDisk Cruzer Micro MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
PNY 2GB microSD Memory Card Logo
241 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
