Question about Carrier 38CKC042 Air Conditioner
Fan wont turn off
Compressor fan on central unit stays on. I have unplugged the central and turned the thermostat off but when I plug turn the breaker back on the fan comes back on.
    Sergeant:
  • 340 Answers
The control board is bad safety feature of carrier board . Tom
Posted on Jun 30, 2009
Compressor wont start up fan in freezer stays on
        • Pull the fridge out from the wall and check to make sure it is plugged in.
        • Unplug the fridge and plug in a spare appliance to see if the outlet is working. Check the circuit breaker to the house see If the outlet is not working to see if there are any fuses that are flipped.Inspect the electrical cord for the refrigerator for damage, such as from a mouse or pet chewing on it.
    • Open the fridge to see if the light turns on. The power to the unit is fine if the light turns on, which means something else is the cause of the starting issue.
    • Turn up the thermostat on the inside of the fridge if it is set to a low setting. Turn it all the way up and listen for the condenser motor to start. Have the unit serviced by a professional if it does not May be internal problem with component
Dec 13, 2013 | Freezers
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
Kenmore central air conditioning unit tripping breaker each time we turn it on.
The breaker tripping when you turn the unit on indicates a 'direct short' and 99 out of a 100 times the short will be either the outside fan motor or the compressor itself. Either way - you will need a qualified serviceperson to diagnose this problem correctly and make the needed repairs.
Best solution is to call AC person.
However, here's a good way you can get it down to either the fan motor or the compressor.
(1) With all power OFF - disconnect the wires to the fan motor
(2) turn on AC unit (a) if breaker trips it means the compressor is probably the shorted component. (b) if breaker DOES NOT trip and the compressor runs - it means the fan motor is shorted.
(3) If breaker tripped with the fan motor disconnected meaning the compressor is probably shorted you can then (with ALL POWER OFF) 'disconnect the wires going to the compressor' and re-connect the fan motor wires. Turn on power - and if fan motor runs (with compressor wires off) you know it's the compressor that is shorted.
After all this you will now know which of the two (compressor or fan motor) is shorted.
If it's the fan motor you can with 'limited mechanical experience' change the motor yourself, but if it's the compressor you will need to call a serviceperson because of the expertise needed to replace the compressor.
Jun 05, 2011 | Kenmore Heating & Cooling
Everytime my central air unit kicks on my circuit breaker trips. It didn't do this last year or even earlier this year
A circuit breaker 'tripping' everytime the AC unit kicks on 'most always' indicates a direct short (somewhere in the condensing unit), although it is possible that the breaker itself is bad - (but not likely).
Usually the cause of this 'short' will be - either the condenser motor in the condensing unit (outside unit) or the compressor - also in the condensing unit.
If you're mechanically inclined - and "very careful" around electricity - there is a fairly simple way to find out which component is causing the short.
Step 1 - Make sure the condensing unit (outside unit) is completely disconnected (electrically) , i.e. pull the fuses/turn off circuit breaker on outside unit and turn off thermostat.
Step 2 - disconnect the condenser motor (this is the outside fan motor). Note: when you disconnect the wires of the condenser motor "be sure" you mark/write their location, and wrap them in electric tape.
Step 3 - start the AC unit. If the breaker trips again you can pretty much rest assured it's the compressor that is shorted.
To prove it (without a doubt) - go to next step.
Step 4 - "be sure circuit breaker and thermostat is turned off" - and - 'reconnect' the condenser motor - and - then disconnect the compressor wires (mark wires and tape them).
Step 5 - Start AC.
If breaker doesn't trip - you know it's the compressor that is shorted.
If breaker 'does' trip again - then it's possible the breaker itself is bad (not likely) or there is a 'short' in the condensing unit's "wiring" somewhere (not likely).
My guess is that either the condenser motor or compressor is shorted.
Hope this helps.
Good Luck!
Jun 10, 2010 | Heating & Cooling
Hi i have a rheem central air unit. The outside unit does not want to turn on. i just recharged it with freon about a month ago so it cant be that
Check the circuit breaker(s) for the outdoor unit. Then set the thermostat to make the unit come on and see if the contactor pulls in. If it doesn't turn the fan switch from auto to on and see if the indoor fan comes on. If not your transformer could be shot. If the contactor pulled in on the outside unit check the capacitor for the fan and compressor.
May 21, 2010 | Heating & Cooling
AC wont kick on....
The first thing to check is your breaker box. There should be one double breaker for the air handler unit, that's the inside unit, and one double breaker for the compressor, that's the outside unit. Check both breakers. If you're not sure if they've be thrown, click them toward the outside of the breaker box (off position) and then click them toward the inside of the breaker box (on position). If the breakers are on and you still are not getting any A/C take a look at your compressor, (outside unit). If the fan is running at least you're getting power. However, your compressor down inside the unit may not be getting power or it may need to be replaced. The compressor has a start-up cap. If this cap goes bad or the wires from this cap fry or corrode away, this will also keep the compressor from starting but the fan will still run. If the fan is not running it could be caused by a faulty relay inside the compressor cabinet. This relay is supposed to open and close based on a low voltage signal from the thermostat. I believe it's roughly 24 volts. This relay switches on and off the 240 volts for the compressor and the compressor fan. Often this relay goes bad or the wires leading up to it fry. If you?re going to work on the unit yourself make sure all power is shut off. There should be a shutoff switch on the outside wall near the compressor. I?d also shut the breakers off.
Jun 12, 2009 | Honeywell Programmable Thermostat Heater
I have a Amana air command 80 sse central air unit. The unit is comprised of a big fan unit outside, and a unit in my garage. The big fan stays on even though I turn the thermostat off. Do you know what...
This sounds like your condenser contactor, contacts are stuck. They weld together if an ant or other debree get between the contacts. Turn off the electric breaker to the outdoor unit as if the outdoor unit runs without the indoor unit running you may damage your outdoor unit compressor.
I would suggest you call a service company. The part should run retail @ 30 to 40 dollars then the service call charge. This repair should take less than 1/2 hour.
Oct 16, 2008 | Amana Heating & Cooling
Need help
If you mean the breaker trips it probably is drawing locked rotor amps on compressor. Turn thermostat all the way to the left to turn it off. Restore power to unit. If fans inside stay on, that means the power on still on. Then turn thermostat to the rite to turn it back on. If the power fails again after turning thermostat back on the compressor is probably bad. :(
Jan 07, 2008 | True GDM-9 Beverage Cooler
Carrier 38CKC042 Air Conditioner Logo
200 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
