Question about Samsung LN-R408D 40 in. LCD HDTV
How do I remove the back panel from a samsung LN-408D? I have removed all of the screws, but the panel doesn't seem to come off.
  • 67 Answers
Samsung LCD TVs has 12-16 screws that need to be removed before taking back off.
Dont forget the screws that hold the connection panel (SCART, HDMI, etc) and the bottom screws that hold the stand. These are screws i missed when i first opened my Samsung TV.
Good luck !
Posted on Jul 27, 2009
  • 304 Answers
You have not removed all of the screws. The back panel is a little hard to remove. Use a little more force.
Posted on Jul 17, 2009
How to remove the back panel from a samsung lcd tv ln-t1953h
One of two general answers----look to see if screws all around the back of the set--if so set must be safely laid face down(no pressure on screens) and base removed first then the screws. Also some sets in addition have tabs around the back cover that snap the back on---use a thin metal putty knife and probe to snap them loose----left to right etc.
Oct 29, 2012 | Samsung LN-T1953H 19 in. LCD HDTV
My Samsung LN-S2651D has suddenly lost the picture. The sound works, the remote control changes channels, etc, the lcd backlighting seems to be on, but the screen remains black with no trace of an image. ...
This sounds like the LCD Back light Inverter board has failed. The board may need to be replaced. (First check the menu option to make sure the Back-light option is not set to zero or a really low value !)
One test you can try is this.
With the set on place a bright flashlight against the screen. Look around the edge of the flashlight. You should see an image moving. You can not see the full image because the back light is off !
You can find inverter boards for your set from;
shopjimmy.com
Ebay.com
alltvparts.com
other sites by search the internet.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR( replacing board) or have a friend with knowledge/skill you can fix it.
>Unplug the set and disconnect any cables.
> Lay the set face down on a cloth covered smooth surface.
>Remove the back cover.
> Remove the metal shielding covering the board
> Disconnect the cables plugged into the board.
> Remove the screws holding the board in place.
> The new board should have the same part number as the board you are replacing.
> Install the new board with screws.
> Reconnect the cables.
> Replace the metal shielding covering the board
> Replace the back cover.
The Inverter board looks something like;
Apr 01, 2011 | Samsung LN-S2651D 26 in. LCD Television
Remove base from monitor
Hi my name is Roety,
I can help you with your issue ,
To remove the base first lay the TV face down on a soft quilt or couch, the base is held on with four screws that go into the back. With the screws removed pull the stand/base straight out the bottom.
Thats all
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Apr 29, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
How do you take off the front panel on a lns5296d
you first have to remove back cover then remove boards and board brackets then remove LCD panel and that leaves just the front cover.
Nov 18, 2009 | Samsung LN-S5296D Television
How do I remove the stand from my LN-S1951W LCD TV?
The stands, from what I've personally seen, are usually attached with 2-4 screws on the back of the tv or sometimes on the underside of the stand. I've seen it even where the bottom piece of the stand pops off to reveal the screw(s).
Hope that helps :)
Nov 05, 2009 | Samsung LN-S1951W 19 in. LCD Television
My Samsung LNT4032hx, just went off, it makes a clicking noise and the stand by led blinks, Its only 1 yr 3 mos old. What a piece of ****
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts.
Good Luck, Big IRISH.
Nov 01, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Wall mounting tv. How do I get the base Off?
Are you wanting to sell the base? My base is broken and I am trying to buy one.
Jan 03, 2009 | Samsung LN-S4051D 40 in. LCD Television
Loose HDMI Connection
Dont use the HDMI connection OR replace the main board. Its directly soldered to the main board. The back should come off IF you have removed ALL the screws and the little screws things that hold on the VGA connections etc. There are also some obscure screws holdin the back on.
Jul 02, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
LCD TV
There is more than two screws holding the back cover on. I think it is more like 4 to 6. After you have removed all the screws you will nee a flat screw driver to help pry the two halves apart. Be careful the front of the cover has little snaps that help hold the two together.
Jan 05, 2008 | Samsung LN-T1953H 19 in. LCD HDTV
LCD TV Set up
no tips, but if you have tip on how to remove base that would help us out..we hung on wall and cannot remove the 4 screws to remove base, only 2 would come out.
Jan 01, 2008 | Samsung LN-R409D 40 in. LCD Television
Samsung LN-R408D 40 in. LCD HDTV Logo
5,610 people viewed this question
Jerry Greenberg
Jerry Greenberg
