It will only print a few lines and the rest of the page is blank
SOURCE: HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
SOURCE: HP D7460 printing blank pages, no error message
Just needed to be unplugged (both at wall and at printer) for two minutes. Restarted and it worked fine.
SOURCE: the printer acts like it is printing, but doesnt actually print
1. Clean the scanner/copier glass and white scan backing on the inside of the top lid with glass cleaner. If there is any foreign material on the glass or white scan backing, the scanner will include it as part of the image resulting in extra pages.
OR FOLLOW THESE STEPS
This normally occurs because one of the ink cartridges is low on ink. To fix this, do the following:
Replace any ink cartridge that is low on ink.
SOURCE: How can you clean print
just take out the ink cartridge and clean off the bottom of it, that is the print head. you may need to clean under the plastic piece that it sits in. That may have hair or fuzz on it that is dragging across print.
SOURCE: MY HP 8500A HAS STARTED
Solution one: Reset the product
If
there is static interference, or loose connections with the product,
this can result in bands or lines in the copy, fax, or scan output. To
resolve this issue, check the product connections and reset the product Press the Power button (
) to turn on the product.Disconnect the power cord from the rear of the product.Unplug the power cord from the wall outlet.Wait 30 seconds.Plug the power cord back into the wall outlet. Reconnect the power cord to the rear of the product.Press the Power utton (
) to turn on the product.Try to copy, fax, or scan again.If these steps resolved the issue
, you do not need to continue troubleshooting.If the issue persists
, continue to the next solution.
Solution two: Clean the scanner glass and scanner lid
If
the scanner glass or the white underside of the lid has fingerprints,
smudges, lint, dust, or other debris, this can slow performance and
affect copy and scan quality. To resolve this issue, clean the product.Before you begin, gather the following materials:Several clean, soft, lint-free cloths
Mild glass cleaner
CAUTION:
Use
only glass cleaner to clean the scanner glass. Do not use cleaners that
contain abrasives, acetone, benzene, or carbon tetrachloride. These
substances can damage the product. Avoid isopropyl alcohol (rubbing
alcohol) because it can leave streaks on the glass.
CAUTION:
To protect the scanner, do not
spray the glass cleaner directly on the glass.
NOTE:
Do not use paper-based wipes or tissues that can leave fiber residue.
Solution three: Clean the automatic document feeder (ADF)
Use the following steps to clean the automatic document feeder.
Step one: Clean the ADF rollers and separator pad
