Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener keypad
I have a new house and dont know keypad number how can I reset it with new code
    President:
  • 3,197 Answers
On the rear of the opener near where all those white wires go you will find the smart/learn button. Press and immediately release it and then walk over to your keypad and key in any 4 digit code you want and press enter. Should do it for you.
Posted on Jun 29, 2009
I reset my liftmaster/chaimberlain keypad (976LM) and now can't access garage. Is there a default code? No other access into garage (new owner to this house).
Make sure the battery in the keypad is good. You cannot reset the keypad without access to the opener. You will have to find a way into the garage.
A door technician uses a special tool to pull the emergency release after drilling a small hole in the door. The door can then be lifted without damaging anything. A keyed manual release assembly is then installed in the hole to be used if there are problems in the future like a power outage or malfunction like you have now.
Aug 11, 2012 | Sears Craftsman LiftMaster Chamberlain...
I need to reset my keypad, bought a new house...do not know the old 4 digit code, need to reset and set my own??
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
Jun 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need to know how to reset keypad for garage door.
If you pressed and immediately released the smart/learn button and then walked over to the keypad and keyed in a 4 digit code and it doesn't work then the keypad is bad. The model number for the opener is on the door side of the motor unit and starts with 139.
Mar 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
I don't know the keypad code...we just moved into the house. How do I reset it?
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate, and plug the garage door opener back in. The keypad should be programmed.
Nov 19, 2009 | liftmaster Chamberlain Garage Door Opener...
Changing code to garage
If you are talking about a wireless keypad do this: On the rear of your motor unit you will find the smart/learn button. Press and immediately release this and then walk over to your keypad and key in your new code and press enter.
Oct 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Bought a house and it has a craftsman keyless entry pad but I dont have the password to reset it...Is there a way to reset it and enter in a new passcode???
On the back of the motor unit you will find the smart/learn button near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in any 4 digit number you like and press enter. Easy as pie.
Oct 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to reprogram keypad for garage door opener
On the rear of the g. door opener, there is a learn buttom.
The first step is to push this button in.
Then go to the remote and enter the new code you want
Press and hold the enter button.
The lights will blink and or you will hear two clicks.
The code you entered should be learned and ready to use
Sep 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster garage door i dont know the current code how do i reset the keypad?
LIFTMASTER OPENERS HAVE A SQUARE BUTTON ON THE BACK PANEL. PUSH THE BUTTON ONCE AND PUNCH IN THE CODE YOU WANT ON THE KEYPAD - YOU ONLY HAVE 20 SECONDS - THE NEXT TIME YOU PRESS ENTER IT SHOULD OPEN/CLOSE THE DOOR
Apr 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door pad
You need to press and release the learn botton (don't hold it or you will clear all the codes)
If the light bulb(s) on your operator are on the front and/or back, the learn botton is on the back of the operator. If the lights are on the sides of the operator then the learn botton is on the right side (looking from the back of the operator and facing the garage door).
After you press the learn button you have about 30 seconds to press in the new 4 digit code in your key pad then hold the enter button until the light on the operator blinks (about 2 seconds). If this does not work check the battery and try it again.
Aug 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
137 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
