Question about Emerson BAR900 MP3 Player
Wnat to know if emerson player model 414-4 has a charger
I want to be able to charge my mp3 model emp 414-4 with out using my computor.
  • budndow Jul 31, 2009
    Thanks for the info
  • 1313wolfie May 11, 2010
    No one i have contacted with one of those have a way of doing that. Although you can buy a solar charger with a usb connection to it and plug that in from thier!!!
It will charge on a cell charger too. you can use the chrger to the safelink phone, a razor phone, and some boost mobile chargers
Posted on Jul 30, 2009
If you have a razor cellphone you can use that and it charges it for you
Posted on Nov 30, 2009
Charging
MP3 players are charged via the supplied USB cable when it is connected to a computer. It can also be charged by a mains USB adapter charger.
Mar 15, 2012 | Asono Audio Players & Recorders
I have a emerson EMP385-2 can i charge it with a car charger?
MP3 players use the USB cable to charge from the USB port on a computer.
You can also charge the MP3 player using a 5 volt USB charge adapter that plugs into the cigarette lighter outlet.
These adapters are available on the Internet.
Jan 21, 2012 | Audio Players & Recorders
Why wont my media player charge
it has battery or charger proble.
change its battery or charger
Dec 12, 2011 | Audio Players & Recorders
I HAVE A NEXTAR MP3 PLAYER MODEL MA797 I CAN NOT GET IT TO CHARGE WITHOUT THE DRIVER. I CANNOT LOCATE THE DISC. DO YOU CARRY A DRIVER DOWNLOAD?
I don't know about your model MP3 player, but most MP3 players charge via the USB cable. Just connect the MP3 player to a computer's USB port to charge the player or a USB charger.
Jun 05, 2010 | Nextar MA797-20 MP3 Player
Charging the mp3 p,ayer
if you get a usb compatible wall charger(you know what I'm talking about right?) and a small mp3 player usb cord from walmart it should work out fine. You could also go to radioshack and ask for assistance-othats what i would do
May 13, 2009 | Philips Audio Players & Recorders
Can my philips mp3 player use a sansa mp3 player charger
as long as the plug is the same yes you should be able to charge it, i know with my philips mp3 player i can use just about any mini usb charger from cell phones to car chargers to wall chargers
May 10, 2009 | Philips GoGear HDD1830 MP3 Player
I HAVE AN EMERSON MP3 PLAYER VERSION 3.5O.00. WINDOWS MEDIA PLAYER SHOWS THAT I HAVE MUSIC LOADED ONTO THE DEVICE BUT WHEN I REMOVE IT FROM THE USB PORT TO LISTEN TO MY MUSIC... THE MP3 PLAYERS SAYS THERE...
I have an Emerson 2gb MP3 player model EMP 312-2, not sure if this info is for you or not. Make sure you are in the MUSIC MODE, when you use the menu button to go from music mode, voice mode, settings etc. you must push menu button again when the mode you want is hi-lited. I had a similar problem. Files were loaded (my music is on my harddrive already so I just copy to mp3 player) but when I turned player on it said no files. AHA, I finally realized I had somehow got into the voice mode and I did not have any voice files, so it said no files. I then went to Folder Mode and it only said micin.dir and it was empty, THAT WAS BECAUSE I WAS IN VOICE MODE, when I switched to music mode, they were all there. I know this sounds very rudimentary, but I am pretty computer literate and had no idea how I switched to voice mode. Before I figured this out for myself I called Emerson customer service, they said it was bad firmware and send it back. If someone there had walked me through what I just told you it would have saved me a lot of time. Hope this helps.
Jan 23, 2009 | Emerson BAR900 MP3 Player
Recharging batt. on emerson mp3 digital media player
if your mp3 player comes with a usb charge cord and has no bulge in the cord, such as would contain some kind of voltage modification electronics, then it's ok.
   the reason is: both the motorola charger and the usb port are  5 volts, all usb is 5 volts standard, and the motorola charger is labeled 5 volts right on the unit itself.
    The the only possible problem would be if the motorola charger was wired differently. However I have been using my razor charger to charge my Emerson 2GB mp3 player w/no problem.
    Plug in the charger with the mp3 player powered up, you should see the battery icon filling up just as if you were using the usb charger.
    if you are still to worried to try it , then get a voltage meter and test the polarity (weather positive and negative are the same on the motorola charger as the usb cord when plugged into the computer.
Sep 04, 2008 | Audio Players & Recorders
How do i charge a video mp3 player
Hello Shelby312,
The actual charge method and power adapters available can vary from manufacturer to manufacturer and model to model. I can't give you specific advice because you didn't post which MP3 player you are referring to. However, most MP3 players are charged by connecting them to the USB port on your computer using the supplied cord. Alternatively some MP3 players may have optional wall chargers or car chargers available which would enable you to keep the item charged when you don't have a computer available.
Hope this helps.
Ken
"Go Ahead. Use Us."
Jun 24, 2008 | Audio Players & Recorders
Emerson BAR900  MP3 Player Logo
162 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
