Question about Mitsubishi WS-55908 55" Rear Projection Television
Colours are getting out of sync, picture distortion
The colours are getting out of sync and the image warped on the top and bottom with increasing regularity. The image switches between normal and distortion.
  • Mitsubishi Master
  • 3,459 Answers
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see morecolours are getting out of sync, picture distortio - bb0cf99.pngnd find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Mar 25, 2010
Ct 2579 When I main supply made ON & start to switch on by remot control,it does not start but after few minutes then after I again try, then it start to display.so Iassume that some one capacitor...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 10, 2017 | Akai Televison & Video
Shutter speed
Can't be without flash. It is related to the sync speed of your camera, some cameras have 1/200 and few have 1/250.
Feb 02, 2014 | Canon Cameras
Issue with Bernina Activa 130: The stitches seem really loose and raised/bumpy. Not sure how else to describe.
Check that you have got the thread correctly routed on the bobbin case and that there is noticeable 'drag' on the thread when you pull the thread out of the bobbin, in its case. If there's little or no drag, it is likely that the bobbin tension needs increasing. I'm assuming you've set the top tension to thered line. A good check is to load two colours of the same thread type top-and-bottom - when sewing on wide zig-zag, the top thread colour should be the only one seen on the top of the material and the bottom colour should be mostly seen on the bottom ... it's OK to have just a spot of the top colour showing on the underside on wide zig-zag/satin stitch.
Sep 08, 2011 | Bernina Activa 130
When i switch on my Vivitar Vivicam 7024, it switches on normaly and resumes normal function (e.g. taking photos, videos, and looking at images). but the screen itself is damaged, it has a large black...
I'm sorry to say that but the screen of your camera appears to be damaged.
May be YOU didn't drop it, but someone else might have. Most probably the screen was pressed hard against something (might be while stored). That's what the black circle and colour lines suggest. The colour lines are somewhat like colours you see when oil is put on water, isn't it? That means the LCD screen is damaged.
I suggest to take it to repair shop and get the screen replaced, specially if you don't have experience repairing cameras.
Aug 30, 2011 | Vivitar ViviCam 7024 Digital Camera
Curved/warped and completely out of convergence Image
Sounds like you need the convergence amplifiers replaced. Cost approx. $300.00 for expert to repair.
Jun 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Black area in photograph
Unless you are using high-end Nikon Speedlights with camera and flash set for Auto FP High-Speed Sync, your top flash sync shutter speed on the D80 is 1/200 second. The black band you are seeing at faster shutter speeds is because the second curtain of the shutter begins to close before the first curtain reaches the fully-open position (which is when the flash fires). The higher the shutter speed, the shorter the gap between first and second curtains. To get full exposure with flash, there must be an instant when the shutter is fully open -- first curtain completed travel, second curtain not started yet.
"As the speed increases the final image should get lighter" applies to ISO speed. Higher shutter speeds mean less light reaching the sensor, but that's not the cause of the black bands.
Mar 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
Image has bend at top of screen
first reset the setting to factory default. if it persists on a regular image too, either the lens, the tunnel or something else in the optical engine is damaged (from a fall?).
Jul 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Projected image is too large for screen
Good Day Brian;
The warped, too large picture is the same problem, the TV has a convergence problem. ln today's electronics the first thing that should be done on any electronic device is to, reset, unplug TV from the a/c outlet for at least 4-5 minutes then plug back in. If no fix; Your TV has a circuit problem. RCA has three common problems that could cause this condition; the most common is a fuse near the fly-back, IH-VT, the convergence power board or the signal board.
Always, call a factory authorized service dealer if you are not familiar with repairing electronic equipment that contain HIGH VOLTAGE, just for your own safety.
Good Luck, Big Irish.
Jun 21, 2008 | RCA Televison & Video
Double image - colors out of sync, concave image
bad converage ic's, check reisters around them and fuses for -&+VCC
Apr 09, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Proscan Projection screen warped
Just had mine do this same thing today. Looks like its time for a flat screen. Sucks to spend the money though :(
Feb 03, 2008 | Proscan PS50700 50" Rear Projection...
Mitsubishi WS-55908 55" Rear Projection Television Logo
183 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
