Steam not working
I am assuming that the iron gets hot but the steam tank and other steam parts remain cold. The thermal fuse is probably bad. This part costs about $2 but you need to know what you are doing to replace it. The thermal fuse is located in the middle of a wire attached to the top of the water tank.
Send it in for repair.
Google Rowenta Repair Center
SOURCE: my rowenta dg5030 is leaking at the cap
My question is what is Rowenta doing about the gasket problem. Where is the replacement.
SOURCE: Need a cap gasket for a Rowenta DG5030
I showed the part to my husband. He took it to our local Aubuchon Hardware and bought the same size gasket for 59 cents. I just tested it out and my iron works just fine now. The one from the hardware store is black, vs the Rowenta one which is green. Who cares what the color is, no one sees it anyway. However, if you have to send your machine for repair for something else, they may not honor your warranty as you've now added after-market parts. Just thought I mention that. Good luck.
SOURCE: MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
