Question about Lexmark F4270 Plain Paper Inkjet Fax
I just recieved this machine from a friend so i know nothing of its history. ive plugged it up,the power cord and have it hooked straight to a phoneline jack which i have a separate fax nunber in my house besides home number and i get the message on machine that reads error #1203
    President:
  • 3,085 Answers
Are you plugged into the LINE port of the fax mach?
Posted on Jun 30, 2009
Seiki has no picrure #se32hy27
Sounds bad my flat screened friend... without a history of a slow death or brand new out of box or friend sold it to me and said it would last for years smelled hot left on over the holidays for 96hrs straight no history at all I will have to say a logic digital I/O board with a minimum of $95 labor/service call/ troubleshooting.....but there\'s always a chance that the removable cord that plugs into the back of the TV has come loose and just looks like its plugged in(not the wall end) and the TV is to heavy to move and check quickly.... shot in the dark but not bad for "no picture" (could you be any more vague?) just kidding...good luck friend hope Iv\'e helped a smidge~~~> SC
Sep 25, 2014 | Televison & Video
Why thin pink line on the monitor display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
8. If the same pink line shows when you hook it to another computer, it's a problem with the monitor.
Jul 22, 2014 | Dell ST2010 20 inch LCD Monitor
Hi ive got a b&w as2 subwoofer but theres no sound? the power light works but my denon recievers not picking up the sub is there a fuse in the sub which may have blown ive tried all the settings on...
Are you running this subwoofer via an LFE (RCA line level) connection, or via high level (speaker lines in and out of the subwoofer)? There may be different ways to hook up this unit and it would be helpful to know how you have the unit connected. Thanks!
May 04, 2011 | B&W Audio Players & Recorders
My jx fax machine will not print fax or even recieve faxes into history. Power is on and there is a dial tone.
1st. short click onceon power boton.
2nd. ask a friend/client to send you a FAX.
3rd. if it still dose not work you need to get in to the FAX`s menu and check if it is in the correct settings: DIAL TONE or PULS.
4th. repet 2nd. step.
Nov 10, 2010 | Canon FAX-JX200
I recieved a 10 inch 3hp contractor table saw from a friend,for some reason im a bit slow in figuring out how to hook up the power supply plug to the motor. The power cord has two clips that push on to the...
if its 220 use red if not use the other two on the clips are they connected to each other in some way in group of 2 if it is just slip one on each group
Sep 10, 2009 | Saws
Power cuts off periodicly
Maybe. Try a larger guage extension cord.
Jun 11, 2009 | Sony STR-DG820 Receiver
No sound when the tv is on and the mute is turned off
I still am unclear as to your hook up but lets try this, if you have your DVD/VCR plugged into the TV audio and video and a audio cord from the tv monitor out to an input on the reciever, this way you should hear the sound at the tv and reciever.
However if you have your DVD/VCR plugged into the reciever first audio and video connections made at the reciever you should just have a video cord fromthe monitor out of the reciever to the tv and your audio will come from the reciever
Feb 25, 2009 | Panasonic PT-52DL10 52" Rear Projection...
Infinity ps-10 powers up but no boom
Try hooking up a different signal input to your powered sub, another stereo or even a dvd players audio output to the sub will work for a test. Just make sure the subs gain is down before starting. If it still not producing sound, the subwoofers amplifier is bad. I hope this helps.
Oct 10, 2008 | Infinity PS-10 Subwoofer
No power
I have a friend that had the same problem, I opened the machine and found that the fuse had blown. Took a small piece of wire and just touched it, very brief, and every thing came on, just breifly to test, not prolonged because you don't the rated fuse for that part, I now know what is the problem, I just have to get the fuse and souder it in.
May 11, 2008 | kawasaki PVS-10921 Portable DVD Player
360 No Longer Turns On
By cord, do you mean the entire AC convertor box? Does the orange light on the convertor box light up? If you used your friends whole ac wire/convertor box (w/ the plug that goes into the xbox itself) and THAT didn't work, then your motherboard took a surge. It is probably trashed as they are VERRRRRRRY sensitive and prone to failure. Time for a new one (or a warranty "repair").
Sep 12, 2007 | Microsoft Xbox 360 Console
Lexmark F4270 Plain Paper Inkjet Fax Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
