Question about Craftsman Gas Mini - Tiller/Edger
Homelite gas Edger blade doesn't engage
. The engine runs on my new homelite gas edger, but the edging blade does not engage. Would anyone know why? and what I can do to get it fixed? tx
4 Suggested Answers
  • 376 Answers
SOURCE: Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
Posted on May 27, 2009
  • 10865 Answers
SOURCE: I bought a Sears edger #536 796526. It dies on me.
Hi Tom. You are not doing anything wrong. That being said, your edger has a slightly gummed up carbeurator. I would go to an auto parts store and get a can of a product called seafoam. this is a gasoline additive. Add one ounce per gallon of gas and use this as the fuel for your edger. You will solve your problem in just a few minutes after using this product, I believe. Give it a try and let me know.
Posted on Jun 13, 2009
  • 8 Answers
SOURCE: Sears edger blade stops spinning, spins in air fine
check the clucth assamble in the head of the edger it sounds like it is slipping
Posted on Aug 16, 2009
Homelite gas edger cuts off after running about 10-15 seconds
The fact that is runs slightly longer on full choke may point still to a fuelling issue.. Does it actually Rev in those 10 seconds or does it just want to bog down and stall.?
May 18, 2016 | Homelite Garden
Why won't my homelite 79cc edger won't stay running longer than 3-4 minutes?
Try taking your exhaust apart and see if it's clogged. There's a spark arrester that keeps sparks form coming out the exhaust. Basically a screen that can get clogged with oil and carbon. The link is a good site for troubleshooting. String Trimmer Repair Help
Jul 17, 2014 | Homelite Garden
Homelite Hedge Trimmer HT-21 engine runs, but blade doesn't move
check the plastic gear where the engine meets the trimmer head
Aug 07, 2012 | Homelite Garden
I bought a homelite curb runner and need to replace the blade. The problem is I cannot find the blades anywhere. Any ideas?
I found that your electric edger blade is rounded on the ends. I did not find a part number for it. I also found a site that has about 30 or more Homelite edger blades listed, but again, with half of them without pictures, I can't give you the edger blade part number. But, if you have removed the blade and can measure all the dimensions of the blade, then you can match it up with one from this site.They have more blades than other sites I checked. It should not be too hard as each blade listed has the critical dimensions listed with it. I wish you good luck.
http://www.mowtownusa.com/42.html?m5:search[keyword]=Edger%20Blade;search[keywordSearchType]=and;search[matchWholeWords]=1;search[keywordFields]=string0:text2:text0:code;search[active]=yes;search[fuzzy_sku]=1
Jun 19, 2011 | Garden
Fuel mixture ratio?
Homelite has a lousy website for technical info but most small 2 cycle engines burn a mix of 50:1
Jun 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Where can I get an owners manual for the Homelite edger UT13140?
This is not a homelite manual.....but it seems to cover an edger exactly like the ut-13140...I had the same edger, and eventually found this:
http://southlandpowerequipment.com/images/southland%20product%20info/S-WLE-0799/manual_S-WLE-0799.pdf
Nov 14, 2009 | Homelite Garden
Homelite edger will not start. cleaned carbs, drained and replaced gas, cleaned screen.
you have to have fuel.fire,compression to run ,make sure you've got that and the thing should run,try a little starting fluid
Jul 18, 2009 | Homelite Consumer Products Tiller...
Jun 13, 2009 | Craftsman Gas Mini - Tiller/Edger
Homelite MightyLite 26cc Edger won't start
You have to make sure the case of the plug is making good connection against the metal on motor. Use file or sandpaper to get good connection on the plug and the motor.
Mar 30, 2009 | Homelite Mighty Lite Lawn Trimmer
Craftsman Gas Mini - Tiller/Edger Logo
173 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
