Question about Garmin StreetPilot C330 GPS Receiver
Can't find satellite signal
I have to shut it down for 20-30 min. If i m lucky, i get signal when i turn it on. it is so irritating. it worked fine to 2 years.
  • in_rohit Jul 01, 2009
    After charging, I can use it for 2-3 hours. So, how come is it a battery problem? Would battery life matters, if i am using with charger now?
  • in_rohit Jul 06, 2009
    Thanks for your detailed comments. I see what you mean. So, if i always run with charger, i shouldn't see any problem. But, if i put on battery, then i will see this issue.
    Brigadier General:
  • 4,090 Answers
Well there's your answer!
it requires a heart transplant ( battery) the average life is 2-3 years depending on use and abuse
Posted on Jun 30, 2009
  • dennis bullard Jul 06, 2009
    if it works on the cvharger just fine but when separated from the charger it fails it is is an early sign of a collapsing battery. It may stay on for 2 -3 hours and run the screen etcetera but insufficient power to maintain the satellite connection via the SIIRFR chip. Beyond this is the isssue that the outgoing PORT is being lost as is the BAUD rate which are all associated with access to satellites and power. After turning off and turning on there is some recovery to the depleted battery and so for a time there is connection.
Nec is shutting down spontaneously.if its on for at least 1hr i am lucky.
May be overheating. Open the case and turn on. There should be a fan working, especially if it's on the CPU.
Oct 14, 2012 | Computers & Internet
Not getting a GPS signal. What do I need to do?
Usually, after you turn on the GPS device, it may take a minute or so to start up and lock into the satellite signals. While it is waiting to get a valid GPS signal, it is "listening" (scanning) for satellite signals to establish your current location.
If you are in the open outdoors, i.e. not inside a building or under extended covers, it should get the satellite signals within a minute or so.
If you still can't get a GPS signal, consider shutting it down ... using a "hard" shut-down (hold down the on/off button for 5 seconds or more ... to re-boot the system/software programs. Then, wait a while before starting it up again. Make sure your device is plugged in and/or the battery is NOT low when you're doing this.
Jan 02, 2011 | Tomtom GPS
Garmin Nuvi 1300 couldn't reach satellite!
THERE ARE A NUMBER OF SOFTWARE UPDATES IN THE LAST FEW MONTHS CAUSING PROBLEMS GO TO WWW.GARMIN.COM/SUPPORT
DOWN LOAD NEW SOFTWARE UPDATES
Dec 12, 2009 | Garmin nuvi 1300 Car GPS Receiver
A35-s159 laptop shuts down suddenly
Sounds like its overheating.Make sure the fans aren't covered up or it has enough clearance for airflow.
Oct 06, 2009 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite temperature related freeze
hum that could be right to avoid wasting money, please get a new board, but if u can get a processor and ram to test with, u might be lucky, right
Jul 17, 2009 | Toshiba Satellite (K000004080) Motherboard
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Frozen/ always says waiting on valid gps signal
The same thing happened to my tomtom and this is how I resolved it. I turned the tomtom off and when I turned it on I held the power button; the screen turned completely green and when I removed the car adaptor the screen went blank. When I turned it back on it found the satellites in under a minute.
Feb 13, 2009 | Tomtom One XL GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
247 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
