Magnavox model TS2768C101
Tv was working fine, unpluged cable from back with tv left on and then unpluged tv. When I went to turn tv back on it clicks on and back off. It seems to cycle approx. every ten seconds if you hold the putton in to power on and power off. It also tries to power up on any of the keys ( menu, volume, channel keys)
I have unpluged tv and waited and tried to power it up with no luck.
my tv was fine, turned it off, won't turn on at all. unplugging, waiting the time then plugging in again, doesn't make any difference. is there a button or something?
  • 1694 Answers
SOURCE: Magnavox model TS2768C101
Requires troubleshoot,locate and replace bad caps in horiz
drive circuit. Usually 47mf/25v..................+ solder any/all
bad connects = prevent maintenance................T.
Posted on Nov 25, 2007
SOURCE: Philips 42PF5320 plasma - unplugged and plugged in. wont turn on
This is a common problem on these plasma TV's. The problemresides in the high voltage boards known as the X and Y Sustainboards.. You can purchase them here for a very reasonable price:
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
Totest which board is failing, you need to check voltage input to theYSUS board first... Input should be 120V from Power supply, outputshould be above 250V.. Do this test with XSUS disconnected. IF 250+Vexists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Posted on Oct 16, 2009
  • 1213 Answers
SOURCE: My 50PFP5332D/37 Philips plasma tv stopped
You may need to replace the Y-buffer to say the least. And if this is not the problem, you will need to replace theY-main board. If the Y-main board is bad you will also change the Y-buffer. Please see a Philips Tech!!!
Posted on Dec 25, 2009
  • 5 Answers
SOURCE: 42"doesn't turn on
if u care to sell the stand that goes with this tv, please email me at
Posted on Jan 05, 2010
  • 616 Answers
SOURCE: My Philips Magnavox 50MF231D/37 won't turn on.
The tv needs the power supply serviced, most likely ( 2) 3300u 10v capacitors. (they can be spotted because they will bulge on top) best to have a pro replace them, however since I am telling you what the problem is try to negotiate a fair price - no more than $150 dollars. you can try to do it yourself but you will need soldering equipment and some level of electronics knowledge. good luck.
Posted on Sep 14, 2010
Our Phillilps Magnavox tv won't turn on.I turned it off by the wall switch and now it won't go back on.The cable went off too but is now on.The cable co. said it sounds like the tv is the problem.I keep...
you might have shorted out the tv since tvs are not ment to be turned on with a wall switch you can take your tv to you local tv repair man it could be just a fuse or the power supply
Oct 03, 2009 | Televison & Video
Magnavox Demo TV
Could you please provide the model number of your TV?
It appears that the TV demo was activated by accident.
Jul 23, 2008 | Philips Magnavox 27MS343S 27" TV
My tv won't go past channel 17
Please try this free Philips Flat Panel Television owners manuals, user guides & how to ... A B C D E F G H I J K L M N O P Q R S T U V W X Y Z ... 13" LCD-TV PF7835 - Philips 20" LCD-TV Product Brochure ... 13MC3206 - Magnavox TV/DVD Combination ... - 674k - Cached
Aug 21, 2009 | Philips Magnavox 20MS233S 20" TV
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Phillips magnavox
Could be an open internal fuse or power supply failure
Mar 18, 2017 | Philips Televison & Video
No Cable Picture
Call the cable co. If your getting the cable setup screen from the tv...Its getting that signal from the box...The tv is fine.
Sep 14, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Magnavox TR2510C101
Pressing the volume up and volume
down buttons on the set simultaneously should work.
Good Luck.
Jul 28, 2008 | Philips Magnavox 27MS343S 27" TV
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
Nov 04, 2007 | Philips Magnavox 27MS343S 27" TV
Do you have a cable box? if so unplug and plug back in the box. I do have issues with boxes doing that, try unplugging the tv also. what have you done to try to fix it?
Jul 08, 2007 | Philips Magnavox 20MS233S 20" TV
Televison & Video Logo
Top Televison & Video Experts
