All functions work but camera won't fire to take photo. worked fine last time used approx. 6 months ago
SOURCE: Fuji FinePix S5000
This appears to be loose connector to the motherboatd from the screen.
Try gentle squeezing of the casing near the bottom of the body
This may do the trick- otheriwise it is a workshop job and frankly not worth the cost - the money would be better spent on a more uptodate camera.
SOURCE: Fuji Finepix Z won't load photos onto my computer
check the memory disc it might be full in which case it is best to save the pics onto your computer and then wipe the disc for room to take more pics.
SOURCE: Pink viewfinder screen and pink photos
I am afraid your CCD is faulty.
No diy possible unless you can find a working CCD-chip.
SOURCE: my flash does not work on my fuji finepix f50fd
Are you sure you don't have the flash suppressed? Somewhere on the menu it should have a flash setting. It can get set to suppress so that it does not flash even in flash conditions.
SOURCE: Fuji Finepix S9600 - Photography mode doesn't work
Sounds like the CCD (main image sensor) is dead. It should be covered under warranty. It doesn't sound like there is anything you've done, or can do to rectify it. Get it in to a Fuji service center with your warranty/receipts.
Testimonial: "Thanks, Steve. I took it to an authorized service center and the CCD sensor was indeed dead. Warranty covered! Thanks again!"
