Question about Siemens HF87950GB Convection Microwave Oven
My Siemens HF879251GB/02 Combi microwave oven was working fine until this evening when the microwave made a odd noise and switched it's self off! On further investigation I found an internal 10A fuse blown. I replaced the fuse and the unit fires up as you would expect with the conventinal oven & grill working fine. But as soon at the microwave is activated the fuse blows. Looking at the microwave there arn't too many things to go wrong. Theres a High voltage capacitor, high voltage transformer, and the Magnetron. Trouble is I'm not sure how to check if one is faulty or if there is anything else I should be looking for?
  • 27 Answers
SOURCE: Siemens HF87950 Internal Bulb replacement
Move unit forward out from enclosure about 20cm....the light is covered by a small panel on top of the casing.(uses torx T20 screws) Remove lid and replace bulb!
Posted on Jun 26, 2007
Falling Down
  • 67 Answers
SOURCE: Siemens HF87950GB /03
If the display is dim and another problem is denoted on the dim display, the problem may be the power supply which may be in common with both items. The power may have surged to a high level before going out which could have damaged the power supply. The only way to know is to probe the power supply with a voltmeter. If the board doesn't show the power levels, usually +5V or +/- 12 V DC, read the values on the electrolytic capacitors on the board. Usually 16 V caps are used on 12 or 5 volt supplies, 32 V caps on 24 V supplies, etc. Be very careful or leave this to a profesional
Posted on Nov 30, 2007
SOURCE: Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Posted on Feb 26, 2008
  • 50 Answers
SOURCE: I have siemens combi microwave oven is working but
Sounds like a faulty thermal cutout switch. Take it to a repairer.
Posted on Sep 22, 2009
SOURCE: My Siemens HTHB86K Micro / Oven combo has
I just had exactly the same problem with the same oven, did you find a solution yet?
Posted on Dec 24, 2010
Microwave not heating. It's showing a unusual emblem
  • Open internal fuse
  • Defective control board
  • Defective door interlock
  • Failed magnetron
Apr 21, 2017 | Microwave Ovens
My miele combi oven microwave doesn't heat but oven is fine!
Probably a faulty door switch has blown the microwave fuse. If you are lucky.
Nov 17, 2017 | Microwave Ovens
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
I have a siemens combi micro oven, which is the best way to cook a christmas cake and at what temp
with the convection part at 325 deg, for 1 hour or less depending on the cake size..have fun cooking..
Nov 17, 2009 | Siemens HB77L55GB 900 Watts Convection /...
Tesco Combi Microwave-doesn't cook but grills ok
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
Sep 08, 2009 | Emerson MW8777W Microwave Oven
Cracked door on Panasonic S753 combi microwave oven
Hi I have a Panasonic combi oven in between the glass door is misting up should I be worried
Jan 07, 2009 | Panasonic NN-S753 Microwave Oven
Noisy Fan in Neff Combi Microwave/Oven. B6774.0gb
yes you can fix it yourself it is a cooling fan in the top it is round metal fan quite small venting waste fumes from cavity when grilling etc need to remove top panel and 3 screws to remove it is a push in fit.
Jan 15, 2008 | Neff B7740N0GB Microwave Oven
possibly a self-diagnostic service that detects a non-functioning magnetron
May 28, 2007 | Siemens HF26066GB 1000 Watts Microwave...
Siemens HF87950GB Convection Microwave Oven Logo
88 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
