Question about Microsoft Xbox 360 Console
Do i need all cables (red green blue) for the xbox360?
Do i need to plug the blue green and red cables to xbox 360?
    Problem Solver:
  • 5 Answers
No just the other 3 will do red,green,blue are for hd
Posted on Jun 29, 2009
How do i hook up my xbox360 to a 55in philips flat sreen
either with the included component (yellow red white or green red blue, red white(provides HD) or an HDMI cable you supply, you also have to confirm you xbox has a hdmi port on the back (near internet cable)
Mar 02, 2011 | Video Game Consoles & Games
How do i connect xbox to akura apl3268fd4 tv so its in hd
There are two ways to connect it.
1. The cable that came with your xbox should have two sets of plugs on it. One being the red, white, yellow and the other red, green, blue. You need to plug the red, green, and blue plugs into the tv with the same color plugs. You will also have to plug in the red and white for sound. The yellow plug is not needed. There will also be a switch at the base of the cable near the xbox. That needs to be set to HDTV. If your cable does not have the red, green, blue you will need to buy a cable that does have them.
2. You can use an HDMI cable. With that all you need to do is plug one end of the HDMI cable into the xbox and the other into the tv. Not all xbox's have the HDMI output though. If its new i should have it on the back of the xbox near the normal tv output slot.
If you use the red, green, blue you will have to set your tv on the component channel. If you use HDMI the tv will have to be on the HDMI channel
This will give you a more thorough explanation. http://support.xbox.com/en-us/pages/xbox-360/get-started/console/audio-video.aspx
If you found this helpful please give me a good rating. Thanks hope this helps
Nov 21, 2010 | Video Game Consoles & Games
Hooking xbox360 up for HD in component 1
Thats the highest setting, for component, that TV will show. it really is that simple. You would need HDMI connector to possibly go any higher. but I think you will find it is the TV.
Apr 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My xbox 360 dosent give video
Plug in the Yellow A/V connection to your TV's Video input. or if you have the HD cable you have to have the Green, Blue, Red, pluged in to get video, and then the White and Red for the Audio. (HD cable will not work at all on a A/V input on a TV.) HD cables have 2 red plugs, 1 is for audio, and the other is for video, they should be labeled to tell you what one is what, but if they are not, if you flaten the cords, the Audo White plug will separate the 2 reds, and the one that is between the White and either the Green or Blue plug is the other video.
If thats not it, I couldnt tell you, unless you have a bad connection on the back of your 360, or just a bad xbox.
Mar 09, 2010 | Microsoft Xbox 360 Console
How to hook up ur xbox 360 to ur tv to play ur xbox 360
if your using the hdmi cables you have to plug in the green, blue and red cables into the corresponding sockets on the tv, the plug the red and white ones into sockets which are not in the same area as the normal red white and yellow cables, there should be a row of sockets at the bak of your tv:
Green
Blue
Red
White
Red
Dec 22, 2009 | Microsoft Xbox 360 Console
Xbox 360 With One Red Light.
Hello Sir
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shad0w
Nov 25, 2009 | Microsoft Xbox 360 Console
My xbox360 keeps blinking red green why
is there something not plugged in right?
Nov 18, 2009 | Microsoft Xbox 360 Console
How do i install an xbox360?
Plug the power unit into to the back. Plug the AV cable to the back of the TV (match the colors) and the back of the Xbox. You'll either use the red/white/yellow if you have a regular tv, or the red/green/blue if you have an HDTV. Then switch the switch on the AV cable to the right setting (HDMI/HDTV or regular TV). Install the AA alkaline batteries in the controller (or the battery pack if you got the rechargeable battery kit). Plug the power cord into the power unit, then last plug the power cord into the wall. Wait a minute for the power unit to light up and then push the big green Xbox button in the middle of the controller down for three seconds and let it go. It should turn on. If not, find someone local to help you. This is all stuff covered in detail in the owners manual.
Jan 01, 2008 | Microsoft Xbox 360 Console
Sound works but no image
This means the AV cable is not detected, try one of these...
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
If this is helpful at all, please rate, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
Xbox360 video doesn't work
make sure you are using the right cables and that if you have the HD cable you have set the switch to the correct setting. If you are using the composite cable (red white yellow) try plugging it into a different port if the TV has it. If you are using component (red green blue) make sure the switch is set to HD.
Aug 07, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
