Question about Zebra TLP 2824 Printer
TLP 2824 Sebra
My printer starts printing ok, but after few label, the barcode being printed starts moving to the right. It is not the printer, because Y just bought a new one and replaced it. New printer is doing the same. Maybe somewhere in the configuration may be a commnad that makes the image shift to the right?
  • 53 Answers
Is the printer an EPL or ZPL model? i will need to see a hex dump of what you are sending to the printer to pin point the error but it sounds like a label layout issue.
is the barcode content the same on each label? if the barcode content is changing the barcode will grow and move to the right.
Posted on Nov 09, 2007
My zebra tlp 2824 won't line up to the labels
Either your printer needs calibrated: Calibrate Zebra Desktop Printer
Or your label template size( in the software) does not match the label size. I recommend the calibration then looking at the software label templates.
Jan 20, 2014 | Zebra Eltron LP 2824 Thermal Printer
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
How to install zebra tlp 2824-z
finish the instalation, reset the computer. Turn on again, check on printers and fax, if the icon is there, right-click and go to properties, print test label.
Oct 31, 2010 | Zebra TLP 2824-Z Printer
Just one of the double tags is printed on
I assume by double tags you mean 2 labels across the roll.
You need to tell your software that the roll is 2 across.
If using the software that comes with the printer, Zebra designer.
Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
Feb 10, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP 2824 Labels printing upside down.....How do we correct?
Change orientation in the printer driver.
Open printer & Faxes folder, Double click on printer driver icon,
Zdesigner driver, click on properties, click printing preferences, tick the box "rotate 180%" Click apply & ok.
If driver is Zebra TLP2824, same as above, but hit the + on "Paper output" and turn "rorate 180%" on, then click apply.
Nov 16, 2009 | Zebra TLP 2824 Printer
Send a .txt file (zpl language to COM1) to theTLP 2824-Z.
Help!!! I can not print barcode with DOS-command "copy barcode.txt com1". DOS Version is 6.1.7600. The printer zebra TLP 2844 does not recognize the EPL commands.
Jul 28, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2824 Print Orientation
check on the driver, unther the advance tab, if some seting is tick.
if cant check the problem, install the driver again.
Feb 03, 2009 | Zebra TLP 2824 Printer
Zebra TLP 2824 Printer problem
How are you loading the labels in the printer?
Make sure they are secured underneath the black side guides?
Sep 17, 2008 | Zebra TLP 2824 Printer
this happens with me also. it is random. could happen once a day or several for no apparent reason. I am printing thru Terminal Services though.
Jun 24, 2008 | Zebra TLP 2824 Printer
Zebra TLP 2824
are you able to give me 2 print dumps? change the printer port to file and post the files content here and I will tell you if it is a config/software issue, it sounds like the software is not setting the label home position correctly(R command)
Nov 07, 2007 | Zebra TLP 2824 Printer
Zebra TLP 2824 Printer Logo
149 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
