Question about Kenmore 23822 Top Load Washer
Kenmore 80 series wont run at all
I just bought it out of the paper and hooked it up. there is power to it i tested it but nothing works. no water pump no spin no anything. im wondering if its the switch or something else.
mod: 110 23832 100
ser: cm0348126
type: 111
  • 15,935 Answers
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 11, 2010
Kenmore series 80 newer won't fill spin or agitate just hums on cycles and makes no noise on spin cycle
Are you sure the water is on and water is getting to the machine.
If there is no water the water valve will open & hum & nothing else will work till the tub is full.Check the little screens on the water valve behind the hot & cold hoses where they hook up the the machine they get clogged
up sometimes just pull them out and clean them. Hope this helps you
Jan 05, 2018 | Kenmore Washing Machines
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
My kenmore top loader 80 series wont start. I traced power to a black cylinder next to motor. i get nothing, no water fill or motor action in any cycle.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following Whirlpool / Kenmore service manual for top load, direct drive washers.
It has troubleshooting and component testing procedures.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Jun 09, 2010 | Kenmore Washing Machines
Kenmore 80 series washer will not fill. replaced
You will have to have an electrical test done. If it's not filling, that means there's no current getting to the fill valve. Have a qualified technician do an electrical test. But also, have him test the timer, too!
Dec 15, 2009 | Kenmore Washing Machines
Kenmore 80 series. doesnt pump water out; wont spin
lid switch may be bad located on top housing at hinge side of lid if you know what youre doing you could jumper swith and see if it works unplug washer while electric contacts are exposed abd plug back in to test
Nov 17, 2009 | Kenmore 24902 Top Load Washer
My kenmore 80 top load series wont rinse top load wont rinse
drain pump is trying to drain. maybe have something in pump
Jun 22, 2009 | Washing Machines
I replaced the lidswitch on a Kenmore 80 series washer. Nothing
Possible bad pressure switch. Turn unit on and jump out 2 wires at a time (3 wires go to it). See if any of your combinations get unit running (one of them will cause water valve to open); if so then that is your problem. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 23822 Top Load Washer Logo
130 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
