Question about Garden
It wont start it has a light spark is it the coil
    Brigadier General:
  • 4,088 Answers
With a new spark plug set at .020", there should be a fat, snapping, blue spark with a magneto. Electronic systems require several good pulls in succession to generate good spark. Other than setting pole gap, there is not is not much you can do for electronic types except replace the whole unit. Magnetos have points and condenser to play with. The points are usually the prime problem with dirty/oily contacts or improper point gap (.020") at the high point of the cam. Coils are a more rare problem.
Posted on Jul 04, 2009
It mayI have no fire going to the coil or from the coil to the plugs
Have you checked the wiring, the spark @ plug, Power to the coil???
Engine Won't Start No Spark - Auto Diagnosis Repair Help
aa1car.com/library/no_spark.htm
If your engine cranks normally but will not start because it has no spark, or it ... If an engine has a coil-on-plug ignition system with no plug wires, remove one of ...
No-start, No-Spark diagnosing simulated - YouTube
? 5:13
https://www.youtube.com/watch?v=XSWN1M8Hoqo
May 19, 2010 - Uploaded by FrankHurtAuto
Simulation of no start with no spark diagnosing, ... Ignition coiland module test with test light (ScannerDanner Premium lecture) - Duration: ...
getting fire from coil but not to plugs - CarGurus
www.cargurus.com > Questions > Dodge > Ram 1500
CarGurusJun 12, 2013 - 2000 dodge ram 1500 4x4 not getting fire changed distributor cap, coil, pickup ignition, rotor, plugs, plug wires 2 answers. ... 1994 dodge 5.9 just shut off and wont start back up there is no spark or fire from coil or plugs. ... 94 dodge van 318 eng will not start new plugs new crank ...
Ignition Coil Troubleshooting: (No) Fire in the Hole
www.secondchancegarage.com/public/coil-troubleshooting.cfm
Jan 27, 2016 | Cars & Trucks
No spark wont start
The coil in the distributor is THE coil. Try replacing that coil.
Jul 28, 2014 | 1995 Ford Aspire
Check engine light on engine cranks but wont start and there is no spark coming out from sparkplug
The check engine light is most likely a misfire code. You need to check your coil packs for supplied voltage. If you have 12 volts supplied, check your ground to the packs. If your ground is good then most likely the coil pack is pad.
Jul 29, 2014 | 2000 Mitsubishi Galant
Car died while stooped at light
if it won't run on starting fluid then you have a no spark issue. i'd check spark out of the coil to the distributor. you could have a bad ignition control module or coil
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Apr 18, 2014 | 1986 Toyota Cressida
1998 cavalier wont start no spark
If you have no spark try the ignition module, it controls the spark and if you don't have any and the coil is new its the only other option short of wiring or ecu!!
Nov 11, 2011 | 1998 Chevrolet Cavalier
MY 96 PONTIAC SUNFIRE 2.2LITER WONT START AFTER IT RAINS OR IT WILL STALL OUT AFTER BEING TAKEN THROUGH AUTOMATIC CARWASH ANY SUGGESTIONS ANYONE?? THANKS!
check spark plug wires and coils for moistore put some lube on the coil wires check for spark after it wont start if itll crank but not start its 1 of 2 thinks no spark or no fuel usally when the coils get too wet they wont allow spark to come through or will cause it to arc
May 07, 2010 | 1996 Pontiac Sunfire
Wont start no spark
check ignition coil it must have been fried thats why it doesnt give supply to the spark plugs
Apr 07, 2010 | 1994 Mazda 626
I have a 96 chev 1500 4x4 5.7l which wont start. I checked the coil wire for spark to ground but there is no spark. What do I do next?
hook a test light to battery voltage. and touch the white wire coming out of the coil, have someone spin it over if light flashes and no spark replace coil. If light dosen't flash replace ignition module.
Jan 23, 2010 | 1996 Chevrolet K1500
Car wont start
Had any check engine lights come on before you made any changes?
The ignition system uses an ignition coil, crankshaft and camshaft angle sensor along with the car's computer or PCM (power control module). This system can stop working due to a failed ignition module or crankshaft angle sensor.
Testing the ignition system is an easy job that takes about five minutes and can be done using a test light or an extra spark plug. Connect a test light to ground and with one of the spark plug wires or coils disconnected. Crank the engine over while holding the tip of the test light about 1/4 inch from the wire or coil terminal. Keep your hands clear of the test area to avoid accidental shock (non lethal). You can also insert a spark plug into the coil or wire and hold it against a metal ground. You should see a light blue spark in the gap .. which tells you the system is working. If no spark is present suspect that the crankshaft sensor needs replacing which is the most common problem.
But you could also check your relay/fuse box and see if any ignition related relays are bad. One way to check a bad relay is to find another one in the box that is exactly the same ans switch them ... and see what happens.
Helpful?
Good luck on your troubleshooting
Jan 21, 2018 | 1999 BMW 323 Series
Car wont start
test light on neg with key on power at both sides of coil ???? next test light on bat plus put to coil neg and have somone turn car over if test light flashes and still no spark coil is bad if test light no flash ignighter is most likely bad the ignighter switches ground on your coil for spark
Dec 23, 2008 | 1994 Toyota Camry
Garden Logo
206 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
