Question about Amana MVH320 Microwave Oven
Amana microwave is loud and doesn't heat. Light
Amana microwave is loud and doesn't heat. Light inside works.
  • William Miller
    William Miller May 11, 2010
    What is the model number?
Magnetron went out causing a short-circuit of sorts. Replace magnetron.
Posted on Feb 09, 2011
Microwave not heating
It most likely is either a issue with the inverter (power supply) or the Magnatron (main unit) in this oven.
It could be a thermal fuse inside but the noise sounds more like Inverter or Magnatron.
If not a cheap unit have a shop take a look and get an estimate.
Jun 15, 2012 | Amana Microwave Ovens
AMANA MICROWAVE RFS-12SW2 from subway. I have 3 broken microwaves. and repair guys won't change parts to fix. so i am willing to change it myself. one of them has no heat. two of them doesn't...
AMANA MICROWAVE RFS-12SW2 from subway. I have broken microwave. and repair guys won't change parts to fix. so i am willing to change it myself. one of them has no heat.. any help and manuals? thank you
Jul 24, 2011 | Microwave Ovens
My amana ACO1560AW microwave oven is not heating, all of a sudden and is making a loud hum sound. Worked fine earlier tonight but now it isn't.
Good day!
please open the cover and look for the thermal fuse/protector inside it is usually color white inside the silicon type rubber jsu replaced it and your problem solved..
thanks for using fixya..
Jun 30, 2011 | Amana Microwave Ovens
The microwave turns on but does not get hot. The light is on, the the clock, the timer and everything works, except that the food does not get hot. I tried to heat up some water and doesn not change its...
you need to remove the outer cover,then carefully discharge the high voltage capacitor with 2 insulated screwdrivers or an insulated jumper wire,then test this and the high voltage diode and the internal ceramic fuse for continuity
Nov 15, 2010 | Amana ACO1860 Microwave Oven
I replaced the cooktop lightbulb in my Radarange Amana Mircowave. When I turned the light on there was a loud pop and the breaker flipped. I took the bulb back out(which was now blown) and flipped the...
Yes there are fuses inside.
There are lethal voltages within Microwave ovens that can stay charged up for many days. If you do not understand the hazards, get it repaired by a qualified electrician.
Dec 02, 2017 | Amana Radarange Microwave Oven
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Mircowave blew
inside check transformer and heating element
Feb 27, 2018 | Amana ACO1840A Microwave Oven
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here: http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Microwave Ovens Logo
180 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
foster_mommy
Level 1 Expert
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
