I am using a 16GB card and was told by support that that is the reason it is not working. is there a work around or way to correct?
SOURCE: garmin nuvi 650 unlocking
If you are the legitimate owner, you can send your unit back to Garmin to be unlocked. Be prepared to provide rock-solid proof of ownership because Garmin has a program that prevents stolen units from ever working again. It's one of the reasons that I purchased it. As word gets out that you cannot unlock a stolen unit, thieves will be deterred from stealing them in the first place. And if you try to open the unit to see if there is any easy jumper or something, you will permanently destroy it.
SOURCE: garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
SOURCE: garmin 765T,dont work/cant charge....
Mine did the same thing. Take a T5 torx bit and unscrew the bottom two screws. Gently pry unit apart. I used finger nails. Disconnect the battery wires from circuit board. Leave unplugged for 10 seconds. Plug the battery wires back into the circuit board. Turn unit on and then plug into computer and run the garmin web updater. Download the fix from garmin. Or you can send back to garmin and two weeks later they'll send you a refurbed unit. You'll lose all your saved data. On top of paying the shipping.
SOURCE: when I start my garmin nuvi 765t. it will try to
Download the Garmin Communicator Plugin and Web Updater software from Garmin's website - both tools are free and will load the proper USB drivers for your 765T.
Ensure that the battery is fully charged via the battery strength icon, prior to aquiring satellites.
To reset the 765T: Hold finger or thumb on lower right hand corner of screen while powering the unit on from the off position. This will erase all user data.
