Question about Radio Communications
My Yeasu FT50r wall wart charger all of a sudden does not fit into the radio's charging port. I purchased this radio on line 2 weeks ago. Can anyone offer any suggestions? Rev Glenn
  • 127 Answers
Take 2 walmart and find a phone charger that has same port.
Posted on Jul 16, 2009
My Casio ctk 811ex wont power up anyone more.Is there an internal battery that needs replacing ? What could be causing the problem ? 2 weeks ago it was working fine
ALWAYS start with the "easy" things 1st. Is the AC outlet on the wall working properly? Is the "wall-wart" power supply working correctly? If no defect is found, check the DC power jack located on the rear of the keyboard. Does it seem to be loose or does moving the power supply jack up/down cause any change? New wall-wart power supplies can be purchased from Radio Shack and usually at a lower price than the original factory replacements.
Mar 29, 2015 | Casio Music
The dual charger does not charge the batteries
Simply fix the wall wart. AE6JI 704-745-2067 Extra Class FCC VEC +45 years practical electronics.
There is a fine wire, (under the paper wrapping) or on the transformer, re-close, and it will work 99% of the time.
WARNING random wall warts WILL vary, up to 200% of what their rating label states!
Next time do not have the wall wart plugged into the Wall AC, until AFTER you plug it into the radio.
Jan 09, 2015 | Radio Communications
My midland gxt quit working,why is that
is there power across the charger contacts ?
get a volt ohm meter & check for starters
usually if you leave the wall wart plugged in all the time they burn out & fail
Dec 25, 2014 | Midland Radio Midland Gxt795vp4 36 Mile...
Can the synet07526 get charged from my pc?
The pc port only puts out 5 volts and used for low current applications, so I don't recommend it.
Mar 29, 2012 | Sylvania G-Netbook
I bought a new battery (FNB-RG-67LI) that arrived with 7.6 volts. I installed to the radio and conected to the ac outlet. After 12 hours charging is in 7.6 volts. my radio is the yeasu FT 60 with the...
That is about the nominal full-charge voltage on that battery pack. If the radio works, use it, let the battery run mostly down and recharge it. The FT-60 is a great radio, and mine shows between 7.4 and 7.8V with a fully charged battery, so yours is probably OK.
Sep 02, 2011 | Vertex Yaesu Radio FTH2070 Compatible...
Need adapter/charger
Radio Shack no longer markets a charger/adapter made specifically for the PRO-82, but the 6-volt Enercell AC adapter with a size C Adaptaplug will work with your scanner. Radio Shack total retail for the pair is $30, and you can probably find them on line for even less. You might even luck out and find a compatible 6v wall wart on eBay.
Bill B
Mar 08, 2010 | Radio Shack Pro-82 Scanner
Charger won't charge
The unit is probably bad. Mine just died turned out its the wall wart. The wall wart is a transformer only set up and outputs about 17VAC. The DC conversion is done in the clip. Only option I found was to replace the charger with the new multivolt charger , Upside batteries charge in about an hour to hour+1/2 vice 3 hours.
Jun 13, 2009 | Black & Decker 14.4 Volt Battery Charger...
How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
Apr 12, 2009 | Motorola Talkabout Distance DPS (10...
I am looking for a charger for a kraft tech cordless screwdriver DS01CN-3.6v. i lost it and have wasted many hours on he web. please can you help me.
Copy the entire address below, paste it in the address box. It will take you to the Kraft tech 3.6v cordless screwdriver web page. From there you can order a new charger It is listed under replacment parts. I think it lists for $3.38.
http://krafttechsupport.com/products/product.aspx?ID=5
You could also take it to Radio Shack and they might be able to fix you up with a universal charger.
Mar 17, 2009 | Hand Tools
I need an electrical connection for 2-way Radio charger base.
Check the voltage of the battery and pick something 1-3 volts higher.
If you have an ohm meter you can meter between battery contacts and charger wall wart jack and see which one is positive and negative and match your transformer up to it.
Jan 16, 2009 | Cobra 2 mile FRS 2 pack Value Pack with...
Radio Communications Logo
124 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
