Question about Dishwashers
Leaking input to the top of the dishwasher. Pollypro pipe comes up the back and into the top centre of the machine.... This is squirting out water when on wash cycle. Have undone large plastic nut on iside.. that has rubber washer on it... but the input pipe does not seem to have a washer between this and the steel body of the machine... this seems to be causing the water to squirt out... please let me know whether the washer has disintergrated or whether I need to use some bedding compound to reset the polly pipe.... Thanks
  • admin49 Jun 29, 2009
    Indesit 3000w
  • admin49 Jun 30, 2009
    It is the Upper spray arm tube that comes through the top of the Dish washer.. There is a Nut with an O ring on the inside but nothing on the outside.... I think there should be a gasket on it to create a seal between the cabinet and the Spray arm Tube and the Nut with the O ring on ... PLease advise...
  • 615 Answers
By reading Your problem most probably due to disintegration of washer only. Try with new Washer
1. First try to adhere some wax or gumming material where washer is distingrated...if it solves u r problem or there is low squirt of water. so problem is from disintigrates Washer Only. if not
2. Check the polly pipes use some bedding component.
Posted on Jun 30, 2009
  • Dishwashers Master
  • 2,200 Answers
Hi.
In order to troubleshoot this question for you, I need the exact make and model of your dishwasher. Please post up these details using the comment button. I will then get back to you as soon as I can.
Posted on Jun 29, 2009
  • Radio Code Pro
    Radio Code Pro Jun 29, 2009
    Ok bear with me and I will get back to advise.
  • Radio Code Pro
    Ok - just to be clear - you state that the problem pipe you are referring to is at the top of the dishwasher this would not be an input pipe but rather a discharge pipe. The feed or input pipe to a dishwasher is always at the bottom. The reason the discharge pipe is situated higher up the machine is to prevent dirty water entering back into the machine itself. If it is the discharge pipe you are referring to this can be clearly identified by it being a much larger diameter than the input pipe.
    The problem therefore would seem to be related to the pump cycle when the machine is pumping waste water out as opposed to a problem with water coming in. This is important to realise as it puts an entirely different perspective on the issue. Please correct me if I have misunderstood your explanation on this 'input pipe'.
    I could suggest that you simply use some silicone sealant around the problem area (and it may well come to this) but what is confusing me somewhat in your description is how this pipe is connecting to the machine. The waste pipe normally connects directly to the pump outlet and therefore any leak in this area would occur where the pipe actually attaches to the pump outlet and not the machine itself. Silicone or sealant of any type would not be the most appropriate solution if this is what we are dealing with.
    This machine is quite old and I have been unable to turn up any manual in my catalogue that relates to it so I can get a view of the exact system. However I have a list of replacement parts i.e discharge pipe, internal pump and these all seem quite standard issue.
    Perhaps you can help clarify a bit more on these issues before we proceed as I wonder if I am missing something in your initial question.
C check water light comes on it leaking water from
your main water line on dish washer has a crack in it in the very back so when wile washing dishes its not geting the right amount of water that it suppose to replace cuplen on bad peace of pipe.
Feb 14, 2011 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Anti flood system triggered Favorit 40660 dishwasher
The problem was solved by opening the machine and finding that the bottom "Y" pipe that has 3 inputs is of extremely poor quality and perforates with pin holes allowing a small amount of water to squirt out. This triggers the anti flood and error status lights flash. The outlet pump is activated and machine does not do anything. You need to replace this hose or like I modified it to work from a 32mm Y plastic junction available from most hardware shops. The wire clamps for this was replaced by "jubilee" screw tight clamps.
I worked on a table and also removed the "Brick" placed at the bottom for balance purposes by cutting the back plastic down with a saw. This made the job very easy...
Jan 13, 2010 | AEG 24 in. Favorit 40660i Built-in...
Water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Jul 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Water leaking from dishwasher
check the hose in the back to see if it split could be dry rotted
Jan 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Hotpoint dishwasher model BFI62
water leaking into base of machine. tip dishwasher back and drain out water. then check all seals intact, i.e. around arms, around salt holder etc
Dec 23, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
KitchenAid superba dishwasher leaking
heres a link to your part pook up, pg 6 number 4-5-6 is what i would assume your talkin about, its where the water comes into machine itslef, easy enought ot do your self, simply held on from the inside with gasket and nut. call local parts dist or whirlpool direct for parts
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208194206.pdf
Nov 09, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher is leaking I noticed a pipe downstairs leaking and realized it is from the dishwasher I noticed the seal is wrecked
must need a new air tube or worse still the air chamber has a split in itclean machine out in w/shop and with sides off check out with a light to see where the leak is realy comming from it may be leaking from the top wash feed pipe leaking around pipe to tub
these do fracture there and water running down to base
if so replace feed pipe
Aug 10, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
RE: Frigidaire Refrig/Freezer
try hot water and a turkey baster (or similar squirt device, I got mine at an auto parts store). squirt water into drain. a little messy but a towel or small wet vac should clean it up just fine.
Jun 12, 2008 | GE PTS22SCRBS Top Freezer Refrigerator...
Indesit 18 in. D41 slim line dishwasher
Pull the unit out and tip it carefully to one side. (put some rag down first to mop up the water) then stand the unit back up.
Make sure you can see the back of the unit. put some tissue paper behind the plastic pipe that runs up the back centre of the machine. Turn the unit on and put into cycle. after a few minutes carefully remove the paper if its wet (even a little) the chances are the star shaped lock nut inside is loose or the pipe is damaged. A replacement is readily available and should cost less than a tenner to buy. just make sure you order a new seal as well and get a 20-25mm jubilee clip to replace the one installed.
Apr 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher leak
Jan 21, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
