HP PhotoSmart C7280 All-In-One inkjet printer. When beginning to print 2-page document, paper-feed gears made noisy ratcheting sound, then loud "crunch." Piece of small plastic gear in internal paper-feeder mechanism broken off. (1) Can I fix it myself? (2) Have it repaired for a reasonable fee? or (3) Must I recycle this printer?
That sounds like a fairly simple fix - using your printer's model number, do an online search for replacement parts. If you're fairly handy, you should be able to do the job yourself. If you have a friend or relative who's handy, they should be able to do it. A typical commercial shop will probably charge quite a lot of money (possibly more than the price of a replacement printer) to do the job.
SOURCE: Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
SOURCE: document feeder appears broken in my HP officejet 7310
I'm sure this will solve your issue.
all the best.
SOURCE: Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
SOURCE: HP Business Inkjet 1200 printer always prints the Alignment Page
Normal
0
Could have a corrupt driver.
Disconnect
the printer or at least be sure it is turned off. I'd do
both and when the CD software program asks you to connect the printer
to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: printer spits out blank page
This should solve this problem if you haven't already. It's real simple.
