Question about Yamaha HTR-5650 Receiver
Receiver will not turn on , it comes on for a few seconds and turns off
  • 2,071 Answers
Just open the unit and then check the fuses,if the fuses ok. Then check the filter capacitor in power supply if its ok ,then check the regulator,if its ok. Then check the four transistors output stage of the amplifier. Maybe there is the problem there.
Good luck..
Dont forget to rate:
Posted on Jun 29, 2009
2 Suggested Answers
Hitachi-mex
  • 26 Answers
SOURCE: Receiver turns for a fews seconds then shuts down
Hi.
If the word "OVERLOAD" is in your display, we have a bad channel.
But if only turn off, and the standby led is on all the time, you need change a couple of resistor of 10 Ohms at 2 Watts in main board. But you need disassamble a must all the amplifier. A lot of work, but cheap part.
Best regards.
Posted on Oct 23, 2009
When I turn the unit on, it turns off in a few seconds. There is a flashing standby light.
Power switch relay needs replaced. Its a small black box with a clear piece that comes off, it would be hard to replace yourself.
Apr 05, 2010 | Denon AVR-1601 Receiver
Receiver LED just turns off in 5 seconds
some tvs have a over voltage or over current circuit protection. this is built into the main circuit to avoid further damage to the tv set. Your tv probably has a switching mode power supply and it's shutting down probably due to an over current condition usually a shorted horizontal out transistor, that is why when you replug the ac cord you get the power light indicator come on for a few seconds then turns off. You may have to take the set in to a tech to diagnose the problem or get an idea on the repair cost.
Sep 09, 2009 | Televison & Video
Shuts down after 30 seconds
Maybe the audio amplifier IC are burned
Jun 29, 2009 | Pioneer VSX-D307 Receiver
I turn on my Pioneer VSX-D509S 5.1 surround amp comes on for a few seconds and then it says "powering off"... and shuts off
Disconnect all your speaker wires from the back of the receiver and turn it back on. If it shuts off, you need to have it serviced. If not post a comment and I can walk you thru troubleshooting. Hope this helps
Jun 24, 2009 | Pioneer VSX-D509S Receiver
Receiver Powers off after a few seconds
its a problem of main board circuit tracks.the circuit is getting short so it overheats and the unit turns off.
it needs reparing.
Apr 01, 2009 | Audio Players & Recorders
Viewsat receiver help
did yopu hook the wires up on the back right?Remove the wires and try turnning it on with no sat or wires hooked up if stilldoes that you will need a bringdead viewsat back to live file and try that way.hope i help :)
Oct 11, 2008 | Yamaha HTR-5730 Receiver
Klh home receiver problems
It is not a fuse problem, when a fuse is gone does not start at all.
It is probably the final amp circuit, there is a faulty IC in there that overheats after few seconds and the unit goes off by itself.
Sep 11, 2008 | KLH R3100 Receiver
Klh r5100 turns itself off after a few seconds
It is over heating. Mine did the same thing. Make sure you have plenty of breathing room for it
Dec 05, 2007 | KLH R5100 Receiver
Yamaha HTR-5650 Receiver Logo
440 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
