Question about Neff U1421 Double circotherm Electric Oven
I bought an ex-display Moben kitchen with a Neff GMBH oven Serial No. E-NR, B1641A2GB/01FD8409 unfortunately the appliance has been decommissioned and I have been unable to find a wiring diagram to get it working. Can anyone help?
    Brigadier General:
  • 8,619 Answers
Hi
Please tell me the model number of your Oven unit so that i can provide you with model specific information.
Also tell me whether you need installation instructions for the oven or how to wire it with the mains.
Thanks
Rylee
Posted on Jun 29, 2009
NEFF oven model number meaning ? I'm willing to buy a NEFF oven, but i can't understand difference between two ovens. The one has E-Nr number B58VT64N0 and the other is B58VT68N0. Can someone help me?
The difference is simple. The B58VT64N0 is made of black stainless steel and the B58VT68N0 is made of regular stainless steel. All other specs for the ovens are identical.
Nov 29, 2017 | Neff Ovens
I was cleaning inner glass on oven door & it fell out . how do i fix it pls
Tecnik was a brand used by Moben kitchens who went bust so Tecnik are a non brand now. You may find a kitchen appliance engineer who would pop in and assist but don't hold your breath if it fails later. As a result there are no handbooks to download. Sorry.
Jul 21, 2014 | Tecnik TKC201/3 Electric Single Oven
How can I remove the fascia panel from my Neff double oven? I have a Neff U1552 oven. The display-film strip showing the temperature for the fan oven broke. I have bought a replacement part from Neff and...
did you manage to fix your strip, i have the same problem, all4 strips have broken in the last 6 months on my U1552. how much was the replacement?
Jan 02, 2011 | Neff Ovens
Display works ok, fan works ok, but no heat. Assume element has gone, can this be replaced from the inside the oven without removing unit from built in housing?
I've never worked with a Neff appliance before, but generally, a firm tug will remove the element and a replacement can be firmly pushed in and all systems are go after that. The built in does not have to be pulled out. I suggest you take a look at the owner's manual or call a repair shop in your area that services Neff. If they have the part, ask them if the element can be remove by simply pulling it out.
Nov 01, 2010 | Neff B1644 Electric Single Oven
Er 07
i can't help you with this brand but in almost all oven of this type . inside behind the display board is a tech sheet. it will have all the answer's fault codes are a common way for self diag ovens and other appliances .. mm
Jul 14, 2010 | Neff B1421 Electric Single Oven
Hi, I am in the process of installing a new kitchen. I was recommended to buy Smeg appliances- an oven and ceramic hotplate by a salesperson stating they are very good aplliances, however another...
From experience I have found Smeg appliances to be very reliable.
It is difficult to judge reliability of appliances but generally these days NO appliance will last without some form of brake down. They are not made to the same quality as appliances of a few years ago.
If you stick to german made appliances (Bosch, Neff, inc Smeg ) then they tend to be built to a higher spec.
Regards
Aardvark Repairs
Nov 16, 2009 | Ovens
Oven not heating up
If the oven fan is working o/k, then all you need to do is replace the oven element, a straightforward repair, and cost effective, if no fan, then could be expensive.
Please rate my solution.
Thanks.
Sep 22, 2009 | Neff B1432 Single circotherm plus Electric...
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
Neff B1721 oven
good day,
hope this link below will solve your problem.
kitchen appliances
Oct 20, 2007 | Neff B1721 Compact single Circotherm oven
Neff U1421 Double circotherm Electric Oven Logo
119 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
