Question about Zanussi Washing Machines
Looking for a manual for a zanussi wd1 9091 washer/dryer
SOURCE: Manual
have got the washer/dryer, and no instructions on how to use , please help get my cloths clean and dry. thanks
Posted on May 21, 2007
  • 1294 Answers
SOURCE: Zanussi manuals
Click on 'washing machines' (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Posted on Apr 04, 2008
57 varieties
  • 1653 Answers
SOURCE: my zanussi washer dryer wjs 1397 w drum is not turning
It is most likely that the drive belt is broken and needs repalcing, If you remove the rear panel it will be obvious if it has broken *** there will be a lrge flywheel attached to the drum and no drive belt going to the motor, near the bottom of the machine. These are easy to obtain from any domestic appliance spares store or mail order. They are also very easy to fit.If the drive belt is in place and is reasonably tight (taught) then you may have an issue with the motor. clutch or brake.
Posted on Oct 12, 2009
apart4u
  • 213 Answers
SOURCE: how to fit a door seal on zanussi washer dryer WDT 1085
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
  • 6277 Answers
SOURCE: I have a Zanussi ZKI
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on May 14, 2011
Where would I find a replacement detergent drawer for a Zanussi 1055W washer/dryer?
http://www.ebay.co.uk/itm/Zanussi-Washing-Machine-Washer-Dryer-WDA1055W-Soap-Tablet-Detergent-Drawer/162547763876?hash=item25d89a0aa4:g:fsAAAOSwuxFYzP3t
Nov 06, 2017 | Zanussi WDA1055W Front Load Washer / Dryer
I have a zanussi washer dryer zwd12270w and the lights just keep flashing and does nothing else
I would first check your line voltage to make sure its correct. Next I would try unplugging it for 10 minutes. If thats doesnt work I would then look at replacing the control board.
Jun 16, 2010 | Zanussi ZWD12270 Front Load Washer / Dryer
We have a Zanussi washer/dryer WJS1397W but only a cold feed where we want to put it. We were wondering if this machine could cope with a cold feed only?
It shold not be a problem if the machine gives you a choice choose the cold wash.The manual should tell you which wash cycles are cold wash only.Hope this helps Kind Regards Stefan.
Jul 08, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Zwd1471s washer dryer
E20 code on Zanussi washer dryer ZWD1471
washing machine working but dryer is not .
Any advice please
Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Manual
Jan 24, 2007 | Zanussi ZJD1219 Front Load Washer / Dryer
Washing Machines Logo
142 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
