Question about StarTech.com StarView SV211K 2-port KVM Switch
Press the menu button then the yellow button .nothing happens
Press the menu button then the yellow button . nothing haperns . can not get any boxes up to put any codes in .. can you help
  • davesouth3 Jul 01, 2009
    SORRY DID NOT WORK . IT IS A EUROVOX EX1000SL ..THANKS
    HOPE YOU CAN SILL HELP ME ..
    DAVE
    Scholar:
  • 54 Answers
IS THIS A PROBLEM WI STARVIEW 3 ???
Ah well, not sure but heres a possible solution if it is
Not 100% certain that this'll work but this is what I did & hopefully it'll work for you too - good luck :-
Subject: Star View 3 The Box Super when channels discappear ;o) 1. Press menu then Factory Setting & Enter code 0000 to reset. 2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on 3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o) Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess & press download !!!
Posted on Jun 30, 2009
Dvd playing problems
your tv has a set up menu, make sure that the tv can see the new device, also your remote for the tv should have an input button, scroll through them till you find it.
May 01, 2017 | Televison & Video
Is there a fee to answer this question: How do I cancel closed captioning with the Samsung BN59-00678A? Thank you.
If pressing the cc button on the remote is not working (you might have to press it multiple times in succession) then your cable box/satellite receiver is where the captions are coming from. You have to disable them with the cable box/satellite receiver remote or on the box/receiver itself. There is usually a hidden menu accessed after turning off the cable box and pressing the menu button on it. If you have a satellite receiver and not a cable box there is usually a yellow button to press to add/remove subtitles.
Jul 14, 2011 | Samsung BN59-00678A Remote Control
I need to master reset may Motorola Blur
To Hard Reset the Motorola BLUR MB300 quite differs from other Motorola ANDROID phones.
Do back up all your data stored on your device before doing this procedure, this process will delete all the data on the phone but does not delete the data stored on the microSD memory card.
To hard reset Motorola BLUR MB300
1. Power off phone.
2. Hold camera button and power on phone at the same time.
3. Release the camera button when prompted to.
4. You will see a message screen telling you to press the up or down volume button
5. Press and HOLD the down volume key (ignore message 'Volume Up Key Pressed')
6. When triangle and phone screen appears
7. Press on the screen just above the back key
8. You will now see the "Motorola system recovery" menu
At this point you will have three choices:
1. reboot system now [Menu+Back]
2. apply ssdcrad:update.zip [Alt+S]
3. wipedata/factory reset [Alt+W]
You can simply tap an item to select it.
At the bottom of the screen you can select OK to apply your choice from the menu.
There is also an opportunity to select Hide on the bottom left, I don't know what that does (I tried it and nothing happened).
Selecting Wipe data/factory reset and tapping Ok and the screen changes to a box and a phone (Get it - out of the box) and you see what is happening on the phone.
pick 2
-- Wiping data...
Formatting DATA:...
Formatting CACHE:...
Data Wipe Complete.
Press Menu+Back to reboot
pressing Menu+Back did nothing for me so I tapped 'reboot system now' on the menu and Ok.
The phone restart then will restore back to its factory default state.
Mar 20, 2011 | Motorola Cell Phones
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
Oct 15, 2009 | Acer AL1916W 19" LCD Monitor
Do you have virgin codes for eurovox
you need to reset box and then re insert codes from before
Jun 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Just brought a new Eurovox SL1000
press the menu button then the yellow button
Apr 20, 2009 | StarTech.com StarView SV211K 2-port KVM...
Putting codes into digivox xl
GOTO MENU THEN GO TO SYSTEM INFORMATION AND PRESS OKAY THEN POINT REMOTE AT BOX AND TYPE 1004 THIS SHOULD TAKE YOU INTO A NEW MENU GO TO NAGRAVISION AND PRESS OKAY NOW USE THE LEFT RIGHT BUTTONS TO SELECT EITHER NTL-TELEWEST-C&W USE THE UP DOWN BUTTONS TO GO TO THE CODE AND CHANGE IT THE LETTERS A,B,C,D,E,F SHOULD BE COLOUR CODED IF NOT USE PAUSE TO ENTER A AUDIO TO ENTER B RED FOR C GREEN FOR D YELLOW FOR E BLUE FOR F AND USE THE NUMBERS REQUIRED TO MAKE THE CODE THEN PRESS OKAY THIS SHOULD STORE THE CODE THEN EXIT BACK TO THE TV IF THE CODE DOES NOT WORK TRY ANOTHER HOPE THIS HELPS.
Dec 03, 2008 | StarTech.com StarView SV211K 2-port KVM...
Puttin the new codes into my eurovox
press menu then the yellow button, the boxes will be there to input the codes.
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
"secret menu" doesnt work.
Sounds like you are doing it right, but just to make sure:
  1. Press (but do not hold) the menu button.
  2. Press (but do not hold) the "0" button. This should bring up a "Service Menu" box with 6 question marks.
  3. Press the "0" key 6 times.
As far as I know, this is the only way to get into the service menu.
Feb 25, 2008 | LG VX8300 Cellular Phone
StarTech.com StarView SV211K 2-port KVM Switch Logo
247 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
