Question about Saeco Magic De Luxe Espresso Machine
Water is nothing pumping it try but it stuck
I have a problem after i press the make coffethe machine start to crash coffee bean and then nothing happend the water is not pumping
  • 1,089 Answers
Hi
If you make a pre-ground shot but don't put any coffee in it, and it does the same thing you have a blockage in the brew head.
If it run normally, your grind is to fine. Push the grinder lever to a larger number.
If it still dribbles, remove the brew unit (behind the door)
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the backside towards the machine (looks like an "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (becareful, there is an O-ring, spring and inside a crystal ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the crystal ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers.....
Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
With the brew unit upside down over the towel insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Run another pre-ground without the coffee and rinse it out. Do this once in a while to prevent this
Posted on Jun 29, 2009
My Saeco Xsmall stops before brewing the coffee
1- The grind fineness setting is too fine. Pump is not able to pump through the compacted coffee grounds.
2- The machine is not descaled. The Calcium deposits in the hydraulic system have reduced the pump pressure. The partially clogged water passages can generate a back pressure to reduce pumping pressure. Was the machine descaled in the past two or three moths? If yes, what was the descaling product used?
3- The pump may be air locked and not able to pump water.
4- Oily beans may have been used. Oily beans are poison for the all fully automatic espresso machines. This clogs the grinding chamber or the grinder outlet. This model is made in Romania made in 2006 or after. This machine has a Ceramic Burr grinder 2006 which is a huge problem to clean adjust beans quantity per shot of espresso etc. etc. Occasionally it will dump dry coffee grounds when the quantity of beans powder is insufficient.
Based on the above details, you can figure out what is wrong and fix it. See the exploded parts diagram included, for help. Services Unlimited Inc Parts Guru Since 1988
Dec 29, 2016 | Saeco Coffee Makers & Espresso Machines
! light flashing... machine won't brew coffee - when i press the button to make espresso nothing happens.. I've tried all the troubleshooting options - nothing works.
The machine is sensing one of the following is not properly fitted in.
Check bean lid, brewing unit is properly latch in, dreg drawer and tray is in, and water tank. And make sure the knob is in off position. If all those are properly in ..the green light will start flashing and warming up. When it reaches the working temperature it will start rinsing and it's ready to use.
Oct 11, 2010 | Saeco Odea Giro Plus Coffee Maker
Beans wont grind through.
Return this machine to your retailer for another. Breville has a replacement warranty. Thank goodness because we are onto our 4th machine in 7 months. Many problems. Firstly it leaked water from the front of the machine, second machine grinder wasn't adjustable so it grinded too fine for pump, same with 3rd and 4th machine. We are opting for a refund tomorrow! Good luck.
Jul 25, 2010 | Breville Fresca BES860 2Cup Coffee Maker
When you press the button to make coffee, it makes the noise lake to cat the coffee and nothing happen no water no nothing!do i have to go for service?
The vibrating water pressure pump is not working and it migh be stuck due to scale or damage. Howver if you hear the loud noise of the pump then the problem is the coffee solenoid valve which it might be stuck or damage.
Good Luck
Please remeber to vote for this answer
Feb 22, 2010 | Gaggia Syncrony Compact Coffee...
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
No coffee is coming out of the machine...
in our machine we wanted a stronger coffee so we adjusted the auto grinder (where the coffee beans are housed) to the finest setting thinking the finer the grind the stronger the coffee...after doing this the machine wouldnot make coffee...we sent it away while still under warranty and the tech said that the grind selection was too low so they just turned the grinder back up a notch and it worked fine ....dont know if this will help but it's worth a try!
Mar 26, 2009 | Krups Orchestro Dialog FNF2 Espresso...
The water is not adding to the ground beans , is it plugged?
I haven't seen a Vienna in a long time so I cannot remember if there is a door for preground coffee, if that option is there, open door and press button to make a coffee if you get water, then adjust the grind and dosage on the grinder and try the auto function.
Jan 17, 2009 | Saeco Vienna Digital Coffee Maker,...
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
122 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
