Question about Mag Innovision LT782S 17" Flat Panel LCD Monitor
MAG 700P monitor display goes black after 60 seconds
After display goes black monitor green power light remains ON. Power can be recycled and the display again stays on approximately 60 seconds. Replacing capacitors in power supply did not correct the problem. Monitor reacts the same when attached to two different computers.
  • 1,684 Answers
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Posted on Jul 29, 2009
  • faber
    faber Oct 21, 2013
    probably the lcd lamp needs to be replaced
My monitor (Mag Innovision 700p) is turning on and is showing whatever it would normally show for 2 seconds then short out to black. The green light is still on.
hello
i do believe the inverter part connected to the power supply may need attention (ie: it may require replacing the little PC board). it shorts out becuiase it has very little life remaining , perhaps one of the diodes is dead or a capacitor is hsorting out the current from it
have you brought it to a monitor repair person ? if it means that much to you, bring it in for testing
shoukd cost about $50-$75 to rapair
Nov 02, 2010 | Computers & Internet
PL 9 19" CRT Monitor: my mag innovision lt716s 700p monitor screen keeps...
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 06, 2010 | CTX PL 9 19" CRT Monitor
No power with 700P LCD monitor, No green light, nothing. replaced 2 popped 470 25C caps. Nothing else looks bad. Board 860-ALZ-M713-F
You will need to check for any pico fuses that run along those capacitor lines they may be marked as pf or nf on the pcb
Jan 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
After display goes black monitor green power light remains ON. Power can be turned of and the display again stays on approximately 5 seconds. Replacing capacitors in power supply did not correct the...
The problem can be the lamps are bad, the only way to tell is to remove the lamps, look for poor soldering works where the wires are attached to the lamps, bad lamps will have very dark color at the end of the lamps, just like bad fluorescent lamp you see when it is worn out, anoher sign of bad lamp is pinkish glow when lamp si first turn on. The transistors and caps are good in the inverter section?
Jan 02, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
Screen goes black after a few seconds.
when the screen goes black shine a flashlight on it. If you see a dim image the back light needs to be replaced. Otherwise check the inverter as that may be causing the problem as well.
Sep 07, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Screen goes blank after being on several seconds
Is the green light on (still indicationg power? Ist put your ear to it and switch on - hear any buzzing? Most like the HV Fluro Inverter for the lamps has an issue. For some the 2SC5707 may have gone - common.
May 29, 2009 | Mag Innovision LT776s 17" LCD Monitor
Preview 700 P
you should change al lthe caps in the PSU.. you can get them all from Maplins for a few pounds.
best get 105 centigrade ones
Oct 25, 2008 | Proview XL370B (Black) 17 in. Flat Panel...
Does the MAG LT-456s require drivers
Perhaps your screen resolution is set too high. Try using a different display to set your resolution to 800x600, then attach the MAG display. Adjust from there once it is working...
Mar 08, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Does a bad power supply look like this?
i suggest that you buy a new monitor coz your current monitor is too old...there's some electric component is weaken...its better to buy new than to repair the old one..
Mar 08, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT782S 17" Flat Panel LCD Monitor Logo
903 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
