SOURCE: Jensen VM 9022
Access the setup menu and while there put in security code on remote, 012345, or 543210. Once entered you will gain access to the secret menu, scroll down to the braking option and select the brake off option. Enjoy....
SOURCE: jensen vm9311ts
tengo mi aparato lo repare y ahora no se quiere ver la pantalla le pongo el cable rosado a tierra y nada antes lo hacia liberaba la pantalla ahora no salen unas letras
que tengo q hacer
SOURCE: how do i bypass the parking brake on my jensen
I just installed the vm8013hd and I simply grounded the pink parking brake wire to the chassis prior to connecting the power to the unit and it works just fine. No bypass box, switch, codes, etc. Good luck
SOURCE: i bought the jensen vm8113 for the dvd player. I
To be honest with you, it's a very easy fix. If you read the install manual it shows the parking brake needs a negative (-) to function. In theory you hook this to the parking brake and when it's applied it will sent a negative to the attached wire, thus activating the playback. Just attach this wire to the negative ground on the system or wire a switch and install it in dash. With 1 wire going to the parking brake wire on the cd and the other going to the ground so you can de-activate it when you wish.
