Question about Compaq Computers & Internet
Spilled soda down my laptop... now all I get is a black screen
Power light will come on, but nothing on my screen... Think I fried it????
    President:
  • Compaq Master
  • 1,314 Answers
Yes, unfortunately that is what happened. Soda is the worst on a motherboard.
Posted on Jun 29, 2009
Power does not come on
The soda is really corrosive with the metal inside the laptop. You probably have a fried capacitor that decided to work for a little bit and then shorted out again. Take it in for repairs.
Jan 28, 2013 | Acer Aspire 5745-5425 Notebook
My screen is totally blank
Turn it off for a day or so and let it dry out, it may never work again, however, because you did spill soda on it...
Oct 02, 2012 | Audio Players & Recorders
Spilled soda on toshiba laptop m505, keyboard is not working. keys don't stick anymore but not working. what do you recommend to fix it?
You need a new keyboard. The sugar in the soda caused the damage and will further corrode the keyboard.
I would also recommend that you clean the area where the soda may have spilled to on the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 14, 2011 | Toshiba Satellite A135-S4527 Notebook
After spilling soda on my laptop it turns on and works fine for 1 hour, then screen goes black. I cleaned keyboard fine. Problem is there always. I have to wait for laptop to cool down(fans work fine),...
A soda spill will do this every time. As the Notebook recovers I doubt that the inverter board as gone. But the suger from the soda could be melting and causing a short. The only real solution is to completely dismantle the notebook and clean it with white spirit or similar. It will help if you can download disassembly instructions first! PS Try not to use it for too long without cleaning it.
Oct 29, 2009 | A.B.S . ABS MAYHEM G3 Eclipse R70 NoteBook...
My dell inspiron 1000 also won't turn on
Water spills are terminal for a powered up laptop....especially the older Dv1000s. I am afraid your dv1000's motherboard is fried. There is no resurrecting from that.....you need another motherboard.
Sep 12, 2009 | Dell Inspiron 1000 Notebook
Black screen at boot
I have seen this a few times for 2 different reasons. First you have to determine if the screen is really totally black or if its just that the "back light" bulb blew out. Look at the screen closely and from different angles as u restart the laptop. You may notice that the you can just barely make out the windows start up logo so faded that you think it's totally black. If this is the case, you need to replace the back light. Second time I dealt with this it turned out to be that the sensor (that is at the base of the screen where the display meets the keyboard) was stuck in the down position. Think of it like a car or fridge door...it has a small pin that when the door closes it shuts off the door/inner light. Laptops use the same principle only they may have different switches for this. It is very small and sometimes it looks like a round cushion even. You may have spilled something like soda (which becomes sticky when dried) on the pin and it is stuck in the off position. Use a toothpic and a slightly wet tissue paper around the edges to clear it. Play with it (nicely) to unstick it and once its up...use the toothpick with the damp napkin to carefully remove the material around the button. Obviously you are still seeing the green lights on the screen which tell u that at least the flatscreen is getting power. If this is not the case, you probably have a loose connection between the screen and motherboard. Hence why you get no picture at all on the flat screen. Take it in to be fixed if that is the case. Don't try to tamper with this yourself.
Jun 07, 2009 | Toshiba Satellite M35X-S114 Notebook
Vaio vgn-fe770g spill/no power
It might be ur CPU or mobo or Both...So it is better to take it to nearest service center for check up...
Dec 05, 2008 | Sony VAIO VGN-FE770G Notebook
Nothing happens when I press the power button except the light
Regardless if you don'r feel comfortable taking the comouter apart it needs to be taken apart and looked at. Depending on what got spilled inside the sooner the better. If it was a soda of some kind it could be bad.I would take out the battery and not try it again.
Oct 03, 2008 | IBM ThinkPad T60 Notebook
I NEED HELP
you pretty much wiped out the mother board you can take to the repair shop and they might be able to clean the soda residue out but soda contains sugar and when heated turns to carmel and fry the circuts
Aug 02, 2008 | Toshiba PSAFGU-058002 Notebook
Laptop will not power up.
Two things to try; 1- remove the battery and start on AC only, 2- remove the memory and try one at a time. You might be able to find diagnostic light codes at Dell's support site for this machine. I'm going to say that this is a motherboard issue, and it's probably fried. Laptops and liquid don't mix well.
Jul 25, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
125 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
