Question about HP Officejet 5610 All-In-One InkJet Printer
Everything prints blank, but the ink is fairly new and there are no errors showing up on the screen of my HP 5610 all-in-one printer/ copier/ fax
    Scholar:
  • 24 Answers
Hi !
As you are using HP officejet 5610 printer, so perform the following steps on the printer to print a self test report to check the functionality of the printer.
Press Setup on the All-in-One then Press 2 then press 6.
If you are unable to perform the above steps, then try to make a copy using the scanner glass ( By placing a text document face down on the scanner glass and then press color copy button.).
If the printer make a copy or prints the self test page, then it confirms that the printer is working fine.
The issue could be with the software side. However, if the printer again prints the blank page, when you try to make a copy or printing a self test, then the issue is with the print cartridges.
Be sure that you are using the Hp genuine ink cartridges not refiled nor re-manufacture. Check the expiry date printed on both the print cartridges.
If all are correct, then perform the below steps to clean the print cartridges.
1. Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridges , from the top to the bottom.
2. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
3. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Then perform the below steps to power cycle the All-in-One unit.
1. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet.
Then insert the print cartridges and try to make a copy and check for the result.
Please revert back to me if the issue occurs again.
With regards.
Mike
Posted on Jun 30, 2009
  • 102 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab55
Posted on Jul 17, 2009
Hp officejet 5610 won't show ink levels in windows 7
fallow the steps to get inklevels in every time of printing,
hai reader this option is not from windows Operating System its a printer manafacturer utility fallow the steps to activate it
Start - Printers & Fax (If not available in the list go for control panel and find the printer & fax option) - select the printer proprities - select printing preferences button - their search the option and put tick to activate the show ink levels on the time of printing.
but the softwares displayes displays the ink levels of the cartridge is approximate that is not a true.
Aug 10, 2010 | HP Deskjet 3845 InkJet Printer
I just added new ink in my HP Officejet 5610. The
check expire date
your have clog printhead try cleaning from printer menu
and if it still not alligne s*ck the old ink from the cartridge and refill it with fresh ink
check here how
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Feb 14, 2010 | HP Officejet 5610 All-In-One InkJet...
Faxing, printing and receivng faxes.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
astrtr2
Aug 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Hello, My name is Cherie Hefty. I have an Hp Officejet 5610. I am having problems getting it to print anything. Everything was working properly until I had to switch the black ink cartridge because it was...
hi,
astrtr14
Aug 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer will not print after reinstall of software to macbook
yes ..if the sensor detect that there's is no ink or low ink..it display an error on the screen ..
to determine the status of the ink..
goto your desktop ..
click the printer driver software and select ink status..
good luck.
May 20, 2009 | HP Officejet 5610 All-In-One InkJet...
5610 printing just a line in the middle of the page, else blank!
wow..I could be the FIRST..I am impressed..NOT!
check to see if there is ink, by blotting the print head on damp paper towel.
otherwise..delete and reinstall the printer. could be a software problem.
Apr 11, 2009 | HP Officejet 5610 All-In-One InkJet...
HP J4580 Printing blank pages
fist click the start menu
and click the printer and fax
and select the hp printer and rith cilck the proparties and seat the print colar coular that time
select only black...............ok
Apr 08, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One print text but no image?
I found what might be the solution to this while searching for a problem for another printer series on HP's site. Go to the Printed Page Is Different Than What Appeared on Screen page and scroll down to "Missing graphics or text, or blank pages"
Sep 11, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
192 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
