Question about Gateway 3550GZ Notebook
Gateway 3550 Internet shuts off every 10 minutes
Gateway 3550, Aol, Broadband, Every 10 minutes AOL just shuts off. Does not matter what I am doing. AOL the reconnects fine. I turned off firewalls, antivirus, and all, still does it. Reinstalled AOl 3 times, they say it is not them, time warner says not them, and Gateway wants $200 to "service" me... Any ideas? Got to be a setting iisue. I got it to stop once, no idea how, and when I rebooted it started doing it again!
    Problem Solver:
  • 4 Answers
Re: gateway 3550 Internet shuts off every 10 minutes
I have a gateway laptop with Vista that does the same thing.
In the control panel/power settings, ID what power scheme you are using.
I found that when on power saver mode the wireless and CPU were throttled down to conserve power. In Vista you can adjust these up to max power while keeping the other features on the default power saver settings. It improved the dropped connections dramitically. To end the finger pointing I signed up for connection monitoring using DSL reports ( This service sends a ping to your modem every 10 minutes and charts your ISP uptime. Using this service I was able to determine that it was not my ISP.
Good luck.
Posted on Dec 21, 2007
0 characters
3 Points
How do i get aol search back on my homepage
go to tools ,internet options, select hompage and write that you want
Nov 30, 2013 | Gateway PC Laptops
My Gateway 7510GX shuts down after ten minutes. I
i think there are two causes for this reason.1/ ur processer fan is not working properly. at that time u should get this message as thearmal heat. then ur computer shutdown. 2/ setting of power option my be fixed 10 minnutes. we should kee poweroption always never shutdown.
Jun 11, 2009 | Gateway 7510GX Notebook
Laptop shutting off
go to control panel and click on to power options. in that you can check whether you have accidentally set the notebook to shutdown after 10 min. thanks for contacting fixya!.
May 31, 2009 | Gateway 7320GZ Notebook
Gateway laptop
Try swapping the Memory cards and let me know what happens.
Jan 25, 2009 | PC Laptops
Can't access aol mail after new Netgear modem/router
there is a firewall inside of your router it is possible that you router is blocking the connection... try going to its webpage and looking for the firewall or de-materialized zone setting.. and allow it to be exposed.. then turn the firewall on ur pc back on...
Jan 09, 2009 | Gateway MX7118 Notebook
I dont no how to conect my asus eee pc 2gb to my broadband so i cant use my pc
AOL does not support Linux, so you cannot install their software. Did you tell them you had a Linux PC?
To help further you must explain what your 'network' is.
Do you have a wireless network or do you use ethernet cable?
You should be able to have internet access without needing AOL software.
Please give details of your network and equipment.
Aug 08, 2008 | ASUS Eee 4G Notebook
This error message normally happens because of a corrupted driver. Reinstall the driver for your modem.If you do not have cd's that came with your computer go too acer's website to download here
Now if that is not the cas maybe you are incorrectly installing aol. Start up your aol. If it specifies broadband at login box change to dialup or go to setup and let aol automactically detect your modem. If problem still persists. Reinstall software when prompted make sure you select dialup. Now if you are using broadband and asking for dialup. Or go to the control panel and remove your modem driver, shut down and restart. It should put the modem back.  Any more questions post comment.
Hope this helps you
Oct 25, 2007 | Acer Aspire 3680 Laptop
Gateway 3550GZ Notebook Logo
305 people viewed this question
Top Gateway PC Laptops Experts
Mark Taylor
Mark Taylor
Brian Sullivan
Brian Sullivan
Alex Krenvalk
Are you a Gateway PC Laptop Expert? Answer questions, earn points and help others
