Question about Canon ImageRunner 1600 Copier
Cannon iR1600 bad NIC?
I have a Cannon iR1600 with a NIC. My printer Icon says offline, I checked CAT5 cable (good) no error on NIC but the printer is not connecting anymore. it has been working for about 7 years than just dead any thoughts.
  • shop_cqc Jul 06, 2009
    the Cannon Printer had to be reset doing a system reset, once I did this eveything came back online.
    thanks for your help
  • 92 Answers
When you touch the system key on the painel board does it say trap 0000000,if so do a clear all and put the same information on the machine.
Posted on Jul 06, 2009
  • 149 Answers
Try re-entering network info as though it was a new install and run through the whole connection procedure.
Posted on Jul 05, 2009
Hp deskje d2360 printer showing offline error
On Printer and faxes, right click on your printer and unselect "Use printer Offline". If "Use printer Offline" is not select, then verify you USB cable.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
I have a Canon MX310 we are getting the error printer offline, we have repluged in our cables, tried new cables, rebooted the computer, and turn the printer on and off
Error: Printer is offline
Solution: Set printer from Offline to online
For Windows 7, open Devices and Printers
Right click on the Printer icon and click on See what's printing
Click on Printer to open the drop-down menu.
Click on Use Printer Offline to remove the check mark and allow use online.
For other Windows operating systems, see here.
Jan 25, 2011 | Canon PIXMA MX310 All-In-One Printer
I checked everything, the printer is connected, there's ink, everything is good, but it says it's offline. I clicked "Use printer online", but it's still offline. I tried Refresh, and it's still...
The first thing I would check is the cable. If you're using a USB connection, try a different (and known to be good) USB cable. If that doesn't do it, you may have a damaged USB connection socket at the printer, which is not cost effective to repair.
Hope that's helpful.
Dec 31, 2010 | HP Deskjet F335 All-In-One InkJet Printer
I have a cannon inkjet mp560. when ever I try to print it says "printer is offline" or "printer is not responding. I've tried unplugging the usb cord and turned it off and restarted it, but it will not...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 10, 2010 | Office Equipment & Supplies
Dell E6400 onboard NIC cannot get network connection - "A Cable Is Unplugged". The laptop is undocked with CAT5 cable firmly attached.
I'd suggest updating the NIC driver in Device Manager. But, the message "A Cable is Unplugged" tells me that the NIC port, the CAT5, or the port where is is connected to your modem/router may be faulty. Try moving the cable to a different port on your modem/router, first. Then, try another CAT5. If still a problem, the NIC port is probably faulty. Hope this helps.
Jul 22, 2009 | Dell Latitude E6400 Laptop
Cannon printer offline
Hi. You haven't said what operating system you're using or wether or not this is a recent thing. However if you are using Windows XP or Vista you can go to control panel, printers and scanners, under XP, or printers and other hardware under Vista, right click your printer and see if there is a check/tick against use printer offline. If there is uncheck it and see if that works.
I hope that helps but without anything to go on its only a guess. Good luck
Apr 25, 2009 | Computers & Internet
Will not print ''offline error''
are you attached to this printer thru a network cable cat5 cable or by way of a usb cable if network you need to print a settings page by holding down on of the buttons on the printer and check to be sure tcp/ip is set to static not dhcp and that the address matches what you have set on the pc side
Mar 26, 2009 | Dell 1720dn Laser Printer
Technical suport
Try checking the fuser section,
1- bad thermistor
2-bad thermofuse
3-bad fuser lamp
Aug 07, 2008 | Office Equipment & Supplies
333 people viewed this question
old marine
old marine
