Question about Craftsman Garden
How do i open up my unit to replace the pull rope that start the engine. the rope snapped off.
  • 7 Answers
SOURCE: when pulling the rope to start it doesn't grab for about 5-6 pull
Unscrew the 3 or 4 screws on the outside of the plate that is part of the pull string housing, there are 2 centrifugal pegs that are sticking due to trimmings getting in that area. Inspect, and clean the pegs that fly out when you pull the string. Do not oil (that will only attract more junk later), make sure they are free, and come out when you pull the string. And your problem will be solved.
Posted on May 25, 2009
#1 Taper
  • 1041 Answers
SOURCE: cannot get my trimmer started.
Tom, it sounds like part of the rope has jumped off of the spool. There should be a small piece of plastic with a screw holding the spool in place. It may have worked itself loose.
Jim
Posted on Jun 07, 2009
  • 6 Answers
SOURCE: how do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Posted on Jun 17, 2009
panilling9
  • 284 Answers
SOURCE: as I pull the rope to start the engine, it will no
Try this # 358.795320 go to sears.com lawn and garden and find partsdirect link (upper right)
it will prompt you to enter search by mod# put in the number above and see if this is what you have,once you are there go down to #62 and this may be the part you are talking about
Posted on May 10, 2010
SOURCE: How do I replace the pull rope on the TE 475
How do I replace my pull cord on my weed eater TE 475? I have the parts diagram, I need to know where the cord attaches and what the steps are to rewind the pulley and attach the cord.
Posted on May 28, 2010
Cord will not pull for starting?
Remove the spark plug, this will relieve compression. Then try to pull the recoil rope. If the unit still does not rotate, the unit should be inspected by a dealer.
May 07, 2015 | Garden
Compression lockup
Remove spark plug. Pull rope several times to blow out cylinder. Spray WD 40 in spark plug hole. Pull rope several times. ensure compression is present. Replace spark plug with new one. Spray starting fluid in cylinder before replacing spark plug. Ensure plug wires snaps on tight. Check oil level, fill with 30w oil if required. All mowers have a low oil start cutoff. Clean or replace air filter.
Sep 10, 2012 | Toro Power Lawn Mower
How do i fix the pull start and re tension it so cord retracts?
You take the top of the motor off with the starter, then rewind the spring,then is a good idea to replace the rope with a new one they sell rope at a lawnmower store, get 5 feet or more if the rope is up on the handle, take a piece of rope with you to get the correct size.
Aug 20, 2012 | Electric Earthwise Corded Lawn Mower...
My lawn mower fires up but idles slow and rough
No adjustments. Automatic governor. Replace spark plug. Ensure blade is sharp and oil is full. 30w oil. Always put Stabile in gas. When you remove spark plug pull rope several times to blowout cylinder. Spray a little WD40 in spark plug hole, then pull rope several times. Spray starting fluid in spark plug hole, replace plug, ensure plug wire snaps on tight. Clean replace air filter.
Aug 09, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Motorturns over hard with pullstarter on my gx340 pressurewasher
You have a nice setup, lots of power. The honda gx340 has a compression release built into the engine so it should be relatively easy to start. With the pressure pump under load however, it will be very hard to pull the rope. With water connected hold spray gun open so water is running out tip and pull rope to start (for easy start, remove tip from gun) . If it still feels very hard to pull rope while holding gun open, most likely problem with lubrication in pump or engine valves are not adjusted correctly preventing compression release. If you suspect problem, go to store where you purchased the unit or any store that sells gx340 and pull the rope to get a feel of what force is required to start engine and compare to yours. Good luck.
Feb 15, 2011 | Honda Pressure Washer PSI 3000
Starting rope has pulled away from inside blower. Can I open and reattach with not much trouble?
For a reasonable handy mechanic it is an easy job. What you have to do is expose the winder/clutch assembly and re-knot the end of the rope through the spindle and preload some spring pressure on the rope winder/clutch. You have to judge how much pretension to put on the winder so as to keep the rope wound and not too much that the rope snaps back uncontrollable.
Dec 30, 2010 | Poulan Garden
I have a 5.5 hp gx 160 honda engine. i had to replace the pull rope & now it will not recoil after starting. what did i miss?
re -do it and make sure it's on properly , do not let it snap back hard...that will screw it up every time. Pull it and slowly let it slide beck in. hope that helps
Sep 18, 2010 | Honda 8 HP Engine
Having trouble starting the Honda HG 110 tiller. \r\n When it does start, when I push the choke lever back in the upward position, the engine stops. Is it necessary to "give" it gas when attempting to...
When starting open gas feed a little (enough to start but not flood) . Do not set choke in extreme top position rather rev engine adjusting slightly to where it holds revs. the best as the choke adjusts air flow to burn the fuel.
Dec 10, 2017 | Honda Garden
How to replace starter cord on a victa corvette 400 series mower,cord snapped,i put it back on....now it doesnt retract properly when trying to start it
Not sure what engine that machine uses but they are all similar, you need to prewind the reel before you slip the rope thru the hole, let the spring/reel pull the rope in.
Nov 15, 2009 | Garden
Rope snapped in my recoil starter..
take off the and and turn the coiler on the inside a few turns and when it starts to get tight put a screwdrive through it so it wont spin, put the rope in the hole and bring it out and tie a knot. the turn it gently to release the screwdriver and let it coil the rope back in
Jan 13, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
268 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
