Question about Hoover Vacuums
How do I disassemble my Hoover Core?
I want to disassemble my Hoover Core (A/11272EA) repair the power switch, but I can't get into it. I have removed all visible screws but nothing seems to be coming apart. I am assuming there is a specific order in which the shell comes off. I can see a screw hiding behind the wheel, but can't access it without taking off the wheel. Any suggestions are greatly appreciated.
  • Ydoi May 09, 2015
    Having the same problem. This is the bagless canister drag around model. There are 2 screws behind each of the two large rear wheels that I can just see. It seems the wheels might clip on, but even after a fair amount of prying pressure they wouldn't dislodge, and I don't want to risk breaking the mount/axle/whatever it is...Tempted though! In my case the cord-rewind spring has somehow died. That's why I'm trying to get it apart.
  • Clive Bennett Feb 13, 2018
    i lifted the wheel jently with a scewdriver and turned the wheel at same time and they came off
  • 37 Answers
Http://manualwanted.com/results.php?lang=en&search=HOOVER+11272EA
Posted on Jul 22, 2014
  • 189 Answers
SOURCE: PHV1800 nozzle removal
Here is an exploded diagram which seems to show that the whole nozzle assembly is removed as one piece.
See if it helps:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=65223&typeId=14858&documentId=34001
Posted on Jan 08, 2008
Kazong
  • 152 Answers
SOURCE: Hoover upright vacuum information
cant help with manual but if i may why would u take it apart theres not much to service but to take the belt off turn the machine over and down by the roller there are a few screws take them out the cover should come off and thats it
Posted on Feb 06, 2008
SOURCE: Hoover Flair S2220 cleaner w/power nozzle disassembly instructions
With the head flipped upside down, take a flat tipped screw driver and carefully pry up the rollers on the front the head. Underneath, you'll find a screw. Remove the screw under each roller, and the front cover will come off with ease. The rollers are just friction fit.
Posted on Jan 03, 2009
  • 3 Answers
SOURCE: Hoover S1361, getting it apart
Hi guys,
It was frustrating as hell for me when I tried to get it apart. I have a blog post on how to do it. Hope it helps!
Taking apart the Hoover S1361
Posted on Jan 30, 2009
SOURCE: How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Posted on Apr 29, 2010
Hoover core plus manual
If its a recent model the main factory website probably has one on download. If not slip into a retailers and see if they have a spare.
Apr 14, 2014 | Vacuums
I have a Hoover Hurricane HU4207 2000w. The electric cable has become disconnected inside the hoover. How do I get to it. I have removed the cover housing for the handle pipe. Then all visible screws on...
You have to remove all the screws to uncover the system. After that only you can get to the bottom of the housing. There you will see the entry of the power cable.
Aug 28, 2011 | Hoover Vacuums
Power switch will not turn off.
Greetings,
This is a relatively easy fix for you. What I've done for you is take pictures of this repair on your type of vacuum to make it as easy as possible. I will explain step by step what you need to do in order to fix the switch on your Hoover.
What you'll need to do this repair:
- Phillips head screwdriver
- Needle Nose Plyers
- Hoover Windtunnel Switch
Step 1. Turn the vacuum cleaner so that the back is facing you. Remove the two screws at the top of the vacuum that are holding the handle on the machine. Please see the picture below of the two highlighted screws that need to be removed;
Step 2. After these two screws have been removed, simply slide the handle backwards, and remove it completely from the vacuum and set it aside. You now can see the on/off switch, but you can't easily change it from here, you'll need to complete several other steps before you may remove the switch. Here's what the vacuum should look like after removing the handle:
Step 3. After removing the handle from the vacuum, turn the machine around so the front of it is facing you. Open the bag housing and set the bag door aside. Also remove any attachments that are on-board in the tool storage bin, this model has a hand-held turbo brush stored here. After removing both of these parts, you'll need to unscrew 3 screws that holds the tool caddy onto the vacuum cleaner. I have circled the area where these 3 screws are located:
Step 4. After removing these three screws, pull the tool caddy off of the vacuum by pulling straight forward by using the tool caddy lid. You'll now have access to both the front and the back sides of the switch. Use your needle nose plyers to remove the two wires that are attached to the switch. Be careful when pulling these wires off because if you pull too hard, then it will break the switch terminal off inside of the wire. Most models have the wire that has a plastic covering over the end of it on the top, and the metal terminal is connected on the bottom. The two lead wires that need to be removed are highlighted:
Step 5. After the wires have been removed from the switch, turn the vacuum back around so that the back of the machine is facing you. Simply use your flat head screwdriver to pry the switch off. You may push on the front side of the switch where the wires connect to it in order to give a space so that you can get a screw driver behind it. Here's how it should look:
Step 6. Once the old switch has been removed, simply push the new switch into the open hole. Important: Make sure that the Off setting of the switch is at the bottom, and the part of the switch that says on is on the top, otherwise the switch will be reversed. Re-attach the wires to the switch, with the wire that has the plastic covering on top, and the metal wire terminal on the bottom. The only tricky part of reassembling is when you put the handle assembly back on the vacuum. As you can see, there is a metal cable below the switch. This metal cable controls the self-propelled mechanism. If you look at the handle assembly, you'll see where the self propelled cable sits inside. The easiest way to line these up is to pull the cable up to the top, and then line up the rod inside of the handle that the cable goes in, and slide the handle back on the vacuum.
I hope that this was helpful in fixing your Hoover Windtunnel switch. If you found this helpful, please be sure to rate the repair as helpful by clicking the Thumbs Up Icon in the top right hand corner of the repair. If you have any questions, or need some help on this repair, please just use the Clarification Request option here on Fixya, and I'll be happy to help you further.
If you need any parts for your Hoover Windtunnel, please be sure to check out our website: http://www.govacuum.com
Thanks so much,
Chris J.
GoVacuum
Mar 31, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel vaccum U6445-900 motor not turning on. I removed the screws and located the contacts inside. There is an on-off switch which seems to be stuck Is there a way to replace this switch
There are a number of Hoover vacuums that are subject to a recall due to an overheating on/off switch. Check out this web site to see if your is included. You'll need the model number and serial number from the back of the unit. The manufacturer will direct you to an authorized repair center for a free replacement of the defective switch.
http://www.cpsc.gov/cpscpub/prerel/prhtml05/05156.html
May 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Bad on/off switch hoover U6476
It's probably the power switch. My switch was dicey for a couple years, finally gave out. Easy to replace.
Remove the two screws just above the WARNING on the rear of the upper handle assembly, then slide the whole assembly to the rear of the vacuum.
Remove the dust bag cover. You will see two holes just above the upper corners of the dust bag. Remove the screws from these recessed screw holes.
Open the furniture cleaner cover and remove the cleaner attachment. Remove the single screw that was hidden behind the attachment. Then remove the attachment housing by pulling it towards the front of the vacuum.
Inside you will see the rear of the power switch. Pull off the power wires (don't worry, easy on/off male/female connectors, no soldering).
The switch is held in by tension bars at the upper and lower rear of the switch. Firmly press down on one of both of the upper/lower tension bars, and push the switch through the housing from the rear of the switch.
Replacement part number is 28161067, about $2.50. Shop will charge about $85 to repair it themselves.
Feb 01, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Replace on/off switch on hoover vacuum
My wife picked one up on the side of the road that someone had tossed. The power switch would not turn off. I took the two bolts out of the top part of the handle, and then removed the screws along the back. This will remove the required panels to access the On/Off switch. Once I found the actual on/off button, I found it to be frozen in the "ON" position. After manipulating it for a few minutes, I got the switch to work. This machine now operates great, and I now have a Hoover :)
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Aug 16, 2008 | Hoover U8185-900 Upright Vacuum
Hover F7452-900
Regarding the brushes not turning:
Your filter may need to be cleaned. It is located behind your brushes. With your tanks removed and the cleaner unplugged; tilt your cleaner back. The filter screen located behind your brushes can be removed by squeezing the sides of the filter and lifting and pulling toward you. Clean and replace.
It would be difficult for me to advise you any further without seeing exactly what you have done.
Aug 09, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Power switch will not work
Hoover U6437-900 U6439-900 Windtunnel Upright
seems there is a short in the power switch, is that possible, I have it disassembled and seems there is power going into the on/off button, but will only sporadically turn on
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This could be a defective switch or it could be a loose connection or wire – chances are that it is a defective switch and needs replacement – this could be a slider switch of which does wear out and that is why it will comes on sporadically – if there is a local vacuum cleaner shop in your area they can test the switch and possibly sell you a new one
http://www.hoover.com
Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 02, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
517 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
