Question about Mitsubishi WT-46809 46" Rear Projection Television
Rear projection set
Three colors are separated causing a concave effect Problem - Mitsubishi WT-46809 46 in. Rear Projection Television
  • 4 more comments
  • kevin b Nov 07, 2007
    When tv is first turned on the three colors are seperated causing a concave effect and can last up to a hour then it straighten out. Is there something I can do or is repair called for?
    Thank you
  • cwhitt722 Dec 14, 2007
    3 colors separate and when I go into convergence to default it won't allow me to make changes on the grid. I can adjust the + on blue and red, but it doesn't change the picture when back to the original screen.
    The picture is also very blurred.
  • JGRAVETT Dec 21, 2007
  • vicm43 Dec 29, 2007
    my t.v. is concave most of the time. i don't have color separation though.
  • melvin62 Jan 01, 2008
    Do you have the same Problem?tree color on tv
  • Anonymous Mar 15, 2014
    DIAGRAMAS Mitsubishi WT-46809 46" Rear Projection Television
  • 1,694 Answers
Convergence circuit repair = replace STK392-570 IC's........
Located on center circuit board on large heat sinks........T.
Please rate this solution...................
Posted on Nov 13, 2007
No red color on screen
there are three basic color controlled by electronic circuit, in picture tube gun,one of them not working properly.needs detail analysis
Dec 04, 2011 | Mitsubishi WT-42311 42" Rear Projection...
Screen looks warped
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Feb 22, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt42313. Three pictures, one with each
Thats caused by the convergence Ics having failed. should have the convergence kit for your model. The kits also contain the CD with instructions.
Dec 22, 2009 | Mitsubishi WT-42313 42" Rear Projection...
How do I repair my television. It is a rear
sounds like your horiz output transformer is shorting out
Oct 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color Gun Help?
this tv will need some testing to determine the exact cause but most likely it will need a conversion done, you will need to call your local repair shop to come out and fix the problem
sorry about your tv
Oct 26, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Red and blue colors go across the screen. picture looks concave.
Greetings joanne7,
The issue you are having could be caused by your television needing the convergence adjusted. During production your televison has the three picture tubes that are converged to form a single image on the screen. Over time these can come out of adjustment.
If you go to this link and check pages 57 and 58, it gives you a very detailed guide on adjusting your convergence. I am aware this model number is slightly different than yours, but I own a 47" Mitsubishi and this is the exact procedure we use to do our convergence so I am confident it is fairly universal.
I hope this helps!
Go Ahead. Use Us.
Jun 25, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi WT-42313 color problem
see if this helps you out
Dec 03, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi projection tv
I have a similar problem. I have tried to fix the convergence via the remote and that has not helped. My three colors are separated and the edge of the picture is bent in toward the center. I am going to try a hard reset but i suspect the convergence IC are fried. Since the set is not HD, I will probably replace it if the hard reset does not work.
Nov 22, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Picture problem
Located on center circuit board on heat sinks................T.
Nov 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
