Question about HP LaserJet 6L Printer
Whines like a dentist's drill when the power is on.
Whenyou powe-up, the whine continues for about 8 -10 seconds and then stops, yellow light goes on and remains.
  • 82 Answers
...if all 3 lights are on...
This is a laser mirror motor problem.
If you are a little bit technician then...
Remove all cables, open front panel, remove the cartridge, remove the 2 screws on top and 3 on back side, remove a white latch from underside left (or right i don't remember ).
With a small screwdriver release 4 tabs that hold back cower and remove it.
Pull a little bit on under front edges for releasing two little tabs and remove the whole cover by lifting it..
Now you can see the laser scanner unit with a yellow label on it.
Remove the screw, release the tabs an remove laser cover after removing one or two little cables over it.
You can see now a rotating square mirror fixed over a little disc, secured with a little plastic black tab.
DO NOT TOUCH THE MIRROR WITH BARE HANDS or you will make it dirty .
Rotate the black tab to release the disc, remove the mirror with a clean cloth, and put a small drop of synthetic oil on its rod... that's all.
Hope you can do it.
Posted on Jun 29, 2009
  • Toby Dammit Dec 27, 2012
    Thanks, Finge! It worked! But what you call "a rotating square mirror" is more like a shiny nut with a screw that goes through the center, that screw being what you call "its rod." Just adding a bit of description. Great help. Thanks again!
There is a loud "whining"
Power steering pumps whine when they are low on fluid, or if they are goin bad. Serpentine belts also whine in cold weather or when they are goin bad. Tru spraying just a little WD40 on the belts when its running, if it goes away, you should be thinking about a new belt. If nothing changes, check the power steering fluid, if its full, take to a mechanic
Mar 01, 2011 | 2004 Cadillac SRX
Rearend whines when i accelerate.what is it?
most likely if it whines at light throttle but stops when u get off the gas the ring and pinoin gears are noisy, if it is noisy all the time it is the carrier bearings or the pinion gear bearing.
Apr 23, 2010 | 1990 Jeep Cherokee Limited
Scanner stops partway along path, motor whines
There is an obstacle in the scanner path, or the scanning head guides got bent (unlikely). There could also be something in the rubber drive belt driving the scanning head gears. Try looking inside with a light and check for scratches on the guide. Unfortunately, to fix the problem you'll have to either send the scanner to maintenance, or to open it yourself (voiding the warranty).
Oct 30, 2009 | Canon CanoScan LiDE 90 Flatbed Scanner
Multiple audio noises even when mixer faders are down
100% raidiation problem!
it was wid my denon protech also,
see if earthing is correct for all gears,
try keeping an equidistance of 10"inches between each gadets
May 25, 2009 | Digidesign MBox 2 Mini (USB, includes...
1997 Suburban 4x4 5.7L Transmission whines until it shifts
You rear planetary set is worn from a restricted cooler.
May 06, 2009 | 1997 Chevrolet Suburban
Continuous "whine" @ 1500 RPM only; and jerks/2001 Lincoln LS
Run the car from the top of a hill and let it coast at your whining speed. Put it in Neutral, does the whine disappear?
If not its in the drivetrain (wheels, driveshafts, tranny)
Very unlikely to be the timing belt. If it appears at a fixed speed then its drivetrain, if it whines at fixed revs its the engine.
Most likey the transmission I fear....Tires will also make loud whining noise too though...
Jan 08, 2009 | 2001 Lincoln LS
HP LaserJet 6L Printer Logo
311 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
