I unscrewed the top of an akg d310 microphone and now it no longer functions. What would be the cost to repair this microphone?
2 Suggested Answers
  • 5 Answers
SOURCE: akg c1000s replacement grille
Maybe you could find a local music store that repairs equipment to replace the grill. Sometimes you can find parts on websites like Ebay.
Posted on Oct 28, 2009
Akg repair
spray it with contact cleaner or wd40 and work it back and forth a few times
Jul 26, 2014 | AKG SolidTube Professional Microphone
Hum which is made worse on touching top half of mic. clearly an earthing matter. engineer has checked bottom half but does not know how to get into top half.
I have the same mic, same problem. I disassemled the mic, put it back together, and the problem fixed itself. I can't explain exactly why.
To disassemble the top part of mic, turn the 2 plastic posts inside the mic clockwise.
http://www.akg.com/mediendatenbank2/psfile/datei/96/C4000b4055d1f13eb44.pdf
Mar 18, 2011 | AKG C4000B Professional Microphone
My D112 died midsession. Can it be reconditioned? Is it cheaper to fix or replace?
Being a dynamic microphone there is not much that can go wrong with it apart from:
  1. broken / detached wiring
  2. failed diaphragm capsule
before doing anything else check it isn't a cable fault.
AKG products normally have a 2 year warranty so if it's inside that time take t back for repair / replacement.
Otherwise a competent repairer ought to be able to fix it for you cheaper than replacement
Feb 22, 2011 | AKG D112 Professional Microphone
I have three working AKG C1000S. They all need grills. Who can I trust to service or sell grills?
AKG sells the replacement screen and tube assembly direct from AKG Acoustics, U.S.
+1 818-920-3237
akgusaservice@harman.com
They are expensive, $80.00 each.
Oct 25, 2010 | AKG C1000S Professional Microphone
How can you open an AKG 220 perception mic to repair it? the mic got knocked over and still works, but the inside seems loose, moving around from side to side.
at the bottom of the mic where the xlr connector is you'll find a ring screw with two notches. unscrew this and you con remove the lower housing. The upper housing is hold by 5 screws.
May 13, 2010 | AKG Perception 220 Professional Microphone
AKG C 451 E sometimes it cuts out. It cannot take
It might be a humidity problem.Here is a repair link:http://www.akgmicrepair.com/ Here is where the service documentation can be found :http://www.akg.com/site/powerslave,id,7,nodeid,7,_language,EN,cat,11.html
Oct 23, 2009 | AKG Audio Players & Recorders
Akg c1000s replacement grille
Oct 07, 2009 | AKG C1000S Professional Microphone
Stopped working. occasionally will power up. can't open it.
to open it look where the lead enters the microphone body you will see a circular rebate surrounding the connector, there are two notches opposite each other you will need to buy or make a tool to fit into the rebate and locate into the notches and simply unscrew. do not attempt to unscrew th body as you will damage the microphone..
May 12, 2009 | AKG Perception 100 Microphone
208 people viewed this question
 Grubhead
Grubhead
