Question about Goodman CKL36AR36 Air Conditioner
AC Fan outside running slow
I have a goodman central air unit CK36-1A. The other day I noticed the fan on the outside unit was not running and the unit was hot and seemed louder than usual. It took the fan out and noticed that one of the wires (brown) to the fan had been nicked by the fan. I cut out the nick spliced the wire back together, and taped them to the inside of the unit so they would not get knocked again and when I started the unit the fan was running slower than normal so so I shut it down. It seems to me like I am only getting 110 instead of 220. What should I be looking for to try and repair.
Thanks!!
Brian
  • briora Jun 29, 2009
    The wire is copper, does that make a difference. Would shorting out the capacitor still allow the fan to move at a 110 speed?
  • briora Jun 30, 2009
    Thanks for all of your help. I'm not sure what happened but I lust hooked the fan back up for the heck of it and it working fine!! All I did was take it out last week, took apart the motor to see if I could find anything and put it back together. Not sure what the issue was but I hope it holds. The only thin I can think was the terminal on the capacitor that the brown wire was connected to was bent a little, probably due to the force of the wire getting hit by the fan? I straighten out the termimal and made sure the connection was secure. Maybe the connection was a little loose from being pulled. Not sure but my house is cooling off now. Thanks again for your help, I just found this site today while I was researching this issue and it';s a great resource.
  • 3,361 Answers
The brown wire goes to the capacitor. It probably shorted out with the nicked wire. Replace the capacitor.
Posted on Jun 29, 2009
  • steve
    steve Jun 29, 2009
    A bad capacitor will cause it to run slow. 110volts it will not run at all.
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
Tip
Replacing a condenser fan in centralized A/C
On of the common problem with centralized A/C unit is a bad condenser fan. I have known people who called an ac technician to fix their ac because of a bad condenser fan and suggested replacing the whole unit! Costing them a lot of money when all it needed was a 50 dollars condenser fan! If the condenser fan do not run or it runs only when you give it a push, it'sbad. You will also notice that it is vey hot. When replacing a condenser fan you may want to replace the starting capacitor too. Replacing a condenser fan is not very hard, just make sure that the power to the ac unit is turned off at the breaker box. Confirm that the wires are not live by using a meter or an ac tester. The fan motor are held with brakets sometimes just screws. Most fan you can buy that has reversible rotation by just reversing the plug. Make sure it is blowing upwards. If not reverse the rotation. So if you notice that the unit is not putting out cold enough air and you went outside and noticed the compressor running but not the fan, turn off the AC right away and do not use it untill the fan is replaced. Running the unit with a defective fan can damage the compressor caused by overheating.
on Jul 10, 2010 | Heating & Cooling
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
Outside unit runs, air handler inside runs sometimes Is there a fan relay that will work sometime? can here freon circulating but fan will not run. Can cut off and restart, will come on sometime. ...
Their is a fan relay on combo gas heat and central air conditioning.
The reason is for heat you need slower fan speed than for air. How do they do it? They use a relay to shift the fan from low for to high for ac.
More HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 03, 2010 | Goodman Heating & Cooling
Oustide unit fan won't work
It sure sounds like the out side condenser fan has gone out.If you need to Fix a water hose to run on it like a spray fanning out over the out side coils(condenser)and try and see if it will cool.It will do the trick,until you get it fixed on week days.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Aug 02, 2009 | Goodman CKL24AR24 Air Conditioner
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Goodman CKL36AR36 Air Conditioner Logo
2,036 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
