Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Loss of power.
I have a husqvarna 24hp. 06 mower. i dont know wats wrong. when i worsh under my deck, and for 10 to 15 mins, when i start it, it has no power, popping, and wont hardly even stay running. then all of a sudden it runs fine. ive done this twice already and now it seems to have no power like its only running on 1 cylinder, is there a plug or wire under the deck that is getting wet. ive looked under the deck and dont see anything. ive replaced the air filter, gas filter, spark plugs, put lucas oil gas treatment with new gas in it, was toled maybe the valves need adjusted. have not yet checked for compression, but i dont see how that can have anything to do with being under the deck wen i worsh the grass out from under it. has anyone had this problem, or could give me advice on wat to do, or how to set the valves. THANK YOU.
  • shadron2 May 11, 2010
    how are you getting under deck? are you tilting mower up? that would cause it to run rough for a few minutes
  • 468 Answers
I have a question for you. When you wash your deck, are you tipping your mower up, or on its side a bit? If so, you could be getting oil in the cylinder, as these are very sensitive to it when tipped. It'll act exactly as you describe, and then usually spit a good amount of blue smoke out, then run fine.
Posted on Feb 01, 2010
How do you Assemble the anti-sway rod on a Husqvarna mowing deck?
The anti-sway bar fits into the frame. Then the sway bar then fits into the deck and connects with a washer and clip.
Sep 04, 2014 | Husqvarna Fast Tractor YTH24K48 48" 24HP...
Husqvarna instructions
On ZTRs you raise the whole front of the mower including the deck. To prevent the blades from while loosing and tightening you use a wooden block between the blade tip and the mower deck.
When retightening the blade torque the blade bolt to 45-55 ft/lbs (60-75 Nm).
Jul 30, 2014 | Husqvarna RZ4824F 48" 24HP Kawasaki Zero...
NEED A BELT DIAGRAM FOR THE HUSQVARNA YTH2448T?
should be on top of the mower deck. look around
May 10, 2014 | Husqvarna 24HP 54" Yard Tractor ()
My deck broke where the backet is welded to the deck its only 3 mnth old.
how old is the mower?most new mowers carrey a factorey 1 year warrenty and should be coverd.
Aug 21, 2013 | Husqvarna Fast Tractor YTH24K48 48" 24HP...
Need belt diagram
See page 22....Figure 23...This is a 54" owners manual. Inside are the drive belt and the deck belt diagrams.
http://lawnandgarden.manualsonline.com/manuals/mfg/husqvarna/gt2254_2.html?idRes=599289
Sep 01, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Husqvarna 24hp 54"yard tractor
Hi. Begin by checking your blades, if they are dull they must be sharpened or that alone will bog down the engine. Also time for a new air filter. Happy mowing. J.
Aug 01, 2010 | Husqvarna 24HP 54" Yard Tractor ()
Husqvarna lgt2654 96045000700 ran out of oil
check deck if free to turn and cutter blads are sharp also check the air filter is clear
Jun 19, 2010 | Husqvarna 24HP 54" Yard Tractor ()
Loss of power when mower engaged
this is usually caused by a dirty restricted fuel filter as the engine has more demand put it with the deck engaged change filter and install with the arrow pointing to the carb
Jun 29, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Loss of power when engaging deck
check your compression. if you have a two cyl engine, start it and ground out each cyl (or pull off the plug) see if engine changes the rpms if one don't change check spark and compression on that side. if you only have one cyl go back to checking compression. get back to me with what you find. ps check your belts to mack sure nothing is in the pulleys like a stick and check under your deck to make sure you don't have a grass build up.
May 12, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
556 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
