Question about Brother MFC 210C All-In-One InkJet Printer
I cant copy
My machine want copy, print,scan, or fax
  • 11,896 Answers
The purge cam switch
does not come ON or OFF
even after the purge cam
has been driven by the
specified number of
pulses.
now this is checked everytime the machine is turned on, so doing a maintinace 01 reset probaly wont fix it.
my bet is on that thers paper jamed on the purge unit. push the print head to the left and look were the printhead sits when the machine is turned of (thats the purge unit) located to the right of the mahcine.
look for some ink soaked paper or somthing that doesnt look right.
thers a piece of ruber on a piece of plastic atached to a spring make sure thats in place. check that thers no broken gears,
if all else fails u need a new maintinace unit unless under warranty not worth doing.
Posted on Jul 05, 2009
Copier quality
Most fax machines would have a resolution selector to vary clarity of transmitted documents. The same would also hold true for scanning jobs. I would discount the possibility of the power supply since everything works except for the quality of the copy/fax. If the printer still works OK (quality of print out) then it is the scanner's availability to copy that is the issue. With current prices of all in one printers (fax/scanner), purchase of a new unit might be more practical not only in terms of cost but in downtime.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
When receiving fax, it won't print
make sure the property settings for the fax are not on the Microsoft printer make sure it is set to the local usb printer
Jan 28, 2014 | Brother MFC-J625DW Wireless All-in-One...
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're computer.you want the fax you must check the you're photocopy machine have a fax board.you want the scan & printing connect the photocopy machine to the computer.(network cable)
Jan 27, 2014 | Toshiba estudio 255 Copier
Copy result is blurred
Does the printer scan OK?
Is the platen glass clean?
Dec 10, 2013 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
Fax and print buttons dont work konica minolta 7235
FAX is option do you have the FAX kit installed???, Scan is normally a kit also on that legacy Konica machine. if you have the IP address to the machine place it in your url box, if the machine is networked you should see the copier own web page
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 19, 2017 | Konica Minolta Office Equipment & Supplies
Printer works fine, but when scanning to copy or scanning to fax a line appears right down the middle of the either the outgoing fax or the printed copy. This when using the feed from the top of the...
If it only happens when you copy or fax, as opposed to 'printing"...clean the scanner glass -both the main glass and the narrow **** glass on the left side.
Please rate me.
Mar 31, 2009 | Dell 1815dn All-In-One Laser Printer
Hp1040 fax and copy machine
I solved this problem by returning my fax machine to where I purchased it and exchanged it for another type of hp machine and it automatically goes in long format when it scans long format paper. If it scans short letter form, it automatically copies itself and adjusts itself. Thank you aniway, durl
Nov 25, 2008 | HP 1040 Plain Paper Inkjet Fax
Fax machine won't copy or send a fax.
IT MAY BE A CIS BUT  I WOULD TRY A SYSTEM CLEAR FIRST
FUNCTION *2864 IN SEQ. THEN 01
Sep 30, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother MFC 210C All-In-One InkJet Printer Logo
69 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
