Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Trimmer line will not engage. It runs but will not spin.
2 Suggested Answers
co7196
  • 3433 Answers
SOURCE: Our B&D electric trimmer is now noise maker
Yes you should be able to repair it. Is it a flex or shaft drive? If it'a a shaft, it is the coupler at the motor. If it is a flexible drive the cable may be broken. B&D is is seldom worth repairing. The majority of lawnmower shops won't repair them because of cost.You can try, but you need the owners paperwork to order the right parts. Good luck and at the least, tear it down and see what failed. Start at the string end.. Good luck and make sure it's not plugged in. - Ned -
Posted on May 28, 2010
Why doesn't the cutting head on Stihl F38 trimmer spin?
Maybe the cutter head has come loose from the shaft. make sure the head is engaged to the drive tube properly
Jul 09, 2014 | Stihl Garden
The engine runs fine. The trimmer head does not spin I believes it a clutch problem. How do you test and/or remove it to replace it?
Are the drive shafts engaged properly? you need to remove all the plastic engine covers and handle to access the clutch. I can send you the IPL if you need it.
Jul 27, 2011 | Husqvarna 28cc Gas Line Trimmer
The rod that runs down the shaft spins but the line trimmer itself is not turning
Has square or spline end on cable either is not engaged with end or is broken off at head end. could also been pushed too far up in the motor end.
Jun 12, 2011 | Garden
Put in replacement spool cutting great as usual went edge the head with spool of line wont turn went back to normal position spool will not spin to cut motor runs spool head not engaging how can I fix
pull the head completely off and make sure that the shaft is not broken, if not then line it back into the head slot and put back together and test it out, Tim
May 29, 2011 | Black & Decker 14" Grass Hog Xp...
I bought a new grass trimmer, gardeners choice, it would not start, noticed the end were you put the nylon keeps turning around,some how that shouldn't, .
Your trimmer may not have a centrifugal clutch, and if that is the case, the string head will turn when you pull on the starter rope and it will always rotate with the engine running. The trimmers with the clutch don't engage the drive shaft until RPM's are up to a certain speed and when that speed is achieved, the clutch engages the clutch drum, the flex drive turns and the string head begins spinning.
May 07, 2011 | Garden
I have a Talon electric line trimmer AT2307A. When I press the start button, the bottom attachment with the nylon line does not spin even though the motor is running.
Halfway down the shaft of the line trimmer, you can detach the line trimmer attachment ( this in so you can fit a lawn edger attachment if need be). Unclip the line trimmer at that halfway point and the start the motor and see if that rod inside the shaft is spining, if so, reattach the line trimmer attachment and see if the nylon line spins, if so, it wasnt attached correctly, if not, then there a break in the flexible rod going to the trimmer head, most likely at the bend.
Dec 29, 2010 | Garden
Motor works fine, but trimmer will not rotate
Have an assistant start and hold the trimmer. At idle, there should still be a little drag on the clutches to make the shaft spin on that split shaft trimmer with the accessory head removed. No need to rev it or do anything fancy, but teamwork will make it safer.
Now forget about the engine and clutches - does the accessory head spin freely when turned by hand (removed from engine still!) and with a clear rotation of the shaft end visible inside the connector socket? Is the shaft end square with sharply defines angles, or rounded off? Does swapping in a different accessory function normally and as expected?
Sometimes the nub end of the shaft wears. Worse, the socket on the engine side has eaten itself to pieces. Worse, worse yet, clutches in the engine side that engage the accessory shaft are worn and there is simply no transmission of power. Good luck, hopefully this info will set your boots in the right direction!
May 08, 2010 | Craftsman Convertible 25cc. Gas Line...
My grasshog weed trimmer only spins when it is upside down.
It sounds like the rod that runs from the motor to the head, is either loose or it has broken, so when you turn it upside down that causes it to engage itself and turn. You will have to take this apart and make sure that the holding clamps are in place
May 04, 2010 | Black & Decker 14" Grass Hog Xp...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
143 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
