Question about Motorola Mobility RAZR V3xx Cellular Phone
Using att razr with another gsm provider
I put a bahamian (Bahamas) chip in the Att Razr and the initial screen says contact provider, then it says it wants to configure system, i press ok, but get this message.
WIB command error 40 1B 35
I dont know if its because phone is locked or something. please help
Thanks
SOURCE:
souma
  • 4 Answers
SOURCE: motorola razr v3 can receive text messages but cant send
Call ur service provider's customer care help line . Ask for <message/service center number>.Then go to ur phones message option>click the center -- key> then goto the message setup> text message setup> service center no...>
Change the no. with the number given by the customer care and then click <Done>. come out to the Home screen > restart ur phone
Posted on Dec 07, 2007
  • 61 Answers
SOURCE: how do i connect my razr gsm v3 to the laptop?.where did i get razr gsm v3(r374 usb modem) driver?.
Do quick google search for "razr tethering" you will also need the USB cable for your phone.
Posted on May 01, 2009
  • 3 Answers
SOURCE: moto razr v3xx forgot unlock and seurity codes att couldnt help
If its 4 digit its 1234 if its 6 digits it 000000 if its 8 digits its 0000000
Posted on May 13, 2009
Tarrzn
  • 35 Answers
SOURCE: razr v3 unlocking code for another service
Dead on solution... unlock any v3 razr via this method.
FREE CELL PHONE UNLOCKS
Posted on Aug 23, 2009
  • 80 Answers
SOURCE: Change service providers on Motorola Razr v3xx???
If you have an unlock phone and say for example you're now w. AT&T (cingular). Ofcourse your service will be provided from At&T, however sometimes there's gonna be a possibility that sometimes your service may upper under a different service provider. It's because all service providers sometimes borrows service for their customers from other carriers (roaming partners) if they don't have any coverage in the area, and that's what they call "roaming." However if you're question was say for example .. the phone turns on and it identifies Telstra when you turn the phone on just like when you have an at&t phone and phone identifies at&t when you turn it back on. It's only going to identify that service provider if phone cam from that service provider and unfortunately you can't change it.
Posted on Sep 05, 2009
Display shows INK SYSTEM FAILURE
Hi col_hogan,
The brand and the model of your printer was not provided, however, you may want to try the troubleshooting steps I have below if you have HP Printer that is getting same error or prompt: INK SYSTEM FAILURE.
  • Press * and # at the same time
  • Press 1, 2, 3 and "support R0632M" should display
  • Press > and "information menu" should display
  • Press > and "configuration menu" should display
  • Press OK and "hardware failure status" should display
  • Press OK "failure status: clear". Press OK to clear
  • Press CANCEL
  • Press CANCEL
  • Press CANCEL
  • Turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
  • If the error came back, do the sequence again and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
If this will not work you may want to reply by sending the specific brand and model of your printer.
Hope it helps.
Thank you for using Fixya.
May 04, 2011 | Office Equipment & Supplies
I bought my nokia 5310 in Ft lauderdale and got a number for it but I live in nassau,bahamas and now i need a PUK code to switch my sim card and get a bahamian number. What is the PUK code?
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
Aug 22, 2010 | Nokia 5310 Cellular Phone
Message states: the following ink cartridges cannot be used after device intialization, and must be replaced
Try the following steps to resolve the issue,
1.) Press & hold the * key
2.) press the # key & release both the keys.
3.) Display should say Enter Special Key Combo - Press & release in sequence 1,2 & 3 buttons.
4.) Press and release the right arrow button (or the right arrow icon on touch screen displays) to look for the System Configuration Menu then press OK.
5.) Press and release the right arrow until the Ink Initialization status is displayed.
6.) Press and release the OK button.
7.) Display should say Ink Initialization status: Clear. Press OK to set it.
8.) Press and release the OK button ONCE. (This is very important; do not press the OK button for a second time).
9.) Press the cancel button three times to leave the support menu.
10.) Unplug the unit from the power supply and wait 10 seconds.
11.) Plug in the unit, Follow the on-screen instructions, the unit will initiate the initialization cycle.
Thanks,
Fame..
Oct 23, 2009 | HP Photosmart C6280 Printer
Error 0xc18a0301 - "Ink system has failed" on a Photosmart 6180
Error number 0xc18a0301 on HP printers Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the “Print Photos” & “Red Eye Removal” buttons. Release both buttons. Display should say “Enter Special Key Combo”
B. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
Display says "enter special key combo"
Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal” .
If "support COxxFN0723BR" appears with "uiaux" message, perform the below steps:
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status.
5. Press and release the “OK” button
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Aug 28, 2009 | HP Photosmart D7160 InkJet Printer
Hard time unlocking my sidekick lx
Have you gotten your sidekick lx to work in the Bahamas as yet?
Jul 05, 2009 | Sharp Sidekick LX Smartphone
I need a subsidy code for a Motorola V3 razr
which one is locked? the phone or your sim?
your friend's mobile phone might be sim-locked into a particular network only. T-mobile phones uses only sims that are T-mobile. If you inserted an ATT sim into a T-mobile phone, it is expected to react that way. That is also why, ATT told you to call T Mobile because it was not the responsibility of ATT if their sim won't work into a T-mobile phone (if that was really the case).
that was just a hint. the initial remedy would be is, insert a T-mobile sim into the T-mobile phone first and also confirm to your friend if it was a sim-locked phone.
subsidy codes are exclusively from the company. it's very, very, very (nth power) seldom that one can be provided online (w/c is safe and reliable). so please hope that either my suggestion would work or they will still provide the subsidy code because the case might be beyond the warranty requirements.
Feb 07, 2009 | Motorola Mobility RAZR V3
Fuji A200 xD card uninitialized
OK There are 3 problems that  a company like Fuji should have avoided:
1. Directing one to "re-initialize" the chip and not providing any directions for doing so.
2. Calling it "initializing" in the menu and "formatting" in the camera menu.
3. Building a camera that blitzes the chip when the USB cord is accidentaly disconnected without following the ritual.
The FIX: Turn the camera on. > Switch from the red camera icon to the green arrow icon on the ring around the shutter button. > Press the "menu/OK" button. > Under the "Erase" menu, scroll up to "Format." Press "Menu/OK" button. > Re-format (aka "re-initialize') the chip and lose all images stored on it. Whoppeee!
Nov 25, 2008 | Fuji FinePix A400 Digital Camera
Changing browser from t-mobile to att/cingular
check att/cingular to configure your GPRS/MMS on your phone.
Sep 17, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility RAZR V3xx Cellular Phone Logo
90 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
