Question about Honeywell CT3200 5-2 Day Electronic Programmable Thermostat Heater
How do I restart my airconditioning unit after a power outage?
The air conditioner is a Thermoplus KAC-024. All was working fine until the power went out a few days ago. The programmable thermostat is working as before but will not cause the unit to turn on
    Problem Solver:
  • 14 Answers
If there is a panel you can open at the A/C. There may be a tiny reset button on the circuit board. Just press it and it should come ALIVE!
Posted on Jul 23, 2014
SOURCE:
SOURCE: new programmable thermostats will not operate the furnace or air
did u turn the power off to unit before installing t-stats,if not then mabe blown low voltage fuse
Posted on Mar 28, 2009
  • 232 Answers
SOURCE: Honeywell RTH2310B Programmable Thermostat
i would check to see if thier is a jumper between RC and RH on the stat if no and the red wire is hooked to RH then you need to add a jumper to RC
Posted on Sep 19, 2009
  • 118 Answers
SOURCE: The other day my air conditioner went off and I
change batteries if not then new t-stat
Posted on Oct 24, 2009
kingbrizzle
  • 407 Answers
SOURCE: I have Honeywell programmable eletronic thermostat
This problem is more than likely not the thermostat at all. The best way to see if the thermostat is at fault, is to pull the cover off and you should see a R(Red) terminal and a Y(Yellow) terminal, carefully jumper the two wires together and see if the outside unit comes on. If not, then the problem doesn't lay in the thermostat. You can also jumper the R and G terminals and see if the fan blower motor on the indoor unit comes on if you don't have another person to help. The thermostat is just a switch board for your controls on the inside unit and outside condensing unit. It is all 24v wiring coming from the unit and supplying the power to the correct terminals on the thermostat. Unfortunately, if your problem is not the thermostat, you can have a number of different problems going on. A few places to look.....
1. Breaker box to make sure nothing has tripped.
2. Make sure your indoor unit is still coming on.
3. Outside disconnect box. It will be by the condenser and should have fuses in it (some do not). To check, you will need to ohm the fuses. IMPORTANT: If fuses are blown, you could have a short in the condensing unit which should be checked first before changing fuses.
Hope this helps some and good luck!
Posted on Jul 11, 2010
aquaman987
  • 927 Answers
SOURCE: the thermostat works fine for
If the temperature doesn't drop when the air conditioning is running for some time (two hours), the air conditioner is not working. The problem is not in the thermostat.
Gary
Posted on Jun 15, 2011
Looking to replace a guasar wall aircondition that fits a sleeve the size of the aircondition was 26 3/4 by width is 25 1/4
Fredrich makes one which may work in sleeve or install a new unit with sleeve and put molding around hole in wall .
Oct 01, 2014 | Quasar HQ2051TH Air Conditioner
Kenmore model #596-79872990. After a power outage, even a short one, the motor does not restart. If the unit is unplugged for several days and then restarted it works fine until the next outage. I...
Make sure the mains voltage is correct . if its too low the compressor will overload when trying to restart causing the overloader to kick out, but should only take a few mins to try and restart.
Sep 05, 2013 | Kenmore Refrigerators
Goodman compressor not running after power outage
no reset replace capacitors. check terminals on compressor to see if a wire burned off
Jul 31, 2012 | Goodman Heating & Cooling
Air conditioner won't come on after power outage
i would suggest looking for a hidden reset button on the unit or check any fuses/trips connected with it.
May 30, 2012 | Heating & Cooling
Had a lightning storm,now brand new aircon wont restart,remote is ok
The electrical storm may have caused a power surge and burned out the circuit board. Especially, if the power went out briefly and then came right back on. Most manufacturers recommend turning the unit OFF during a power outage/electrical storm.
Hope this helps you.
Mar 25, 2011 | Heating & Cooling
HOW DO YOU TELL IF 3,3 1/2 PR 4 TPN UNIT
Hi, you tell by the BTU"S it is. 12,000 BTU'S equal 1 ton of cooling. So, if you see a number in the model number like 024 or 030, and so on, 024 is a 2 ton, 030 is a 2 1/2 ton. Just remember this for each ton of cooling, you will have 12,000 BTU'S.
Shastalaker7
024, 030,36,042,48,060.
Jun 12, 2010 | Intertherm P3RA-042K Air Conditioner
Central air unit problem
Check inside that breaker box for fuses.
Sep 06, 2008 | Amana Heating & Cooling
Aircondition displyes E1
After our power went out & came back on, my a/c unit now displays E1 and will not restart. Any help?
Jul 18, 2008 | Amana ACE245R Air Conditioner
Aircondition not working
E1 indicates  Filter needs replacing/Cleaning , this code flashes after 720 hours of operation time.
Disconnect the power plug
Clean or replace filter
HOLD DOWN (dont let go) Of  the ON/OFF button and plug the unit back up and continue to hold the ON/OFF button until you hear a beep
After the beep unplug your A/C
Then plug it back up to and turn it on for normal operation
IF THIS FAILS TO REMOVE THE CODE
UNPLUG A/C  THEN HOLD DOWN THE MODE BUTTON AND PLUG IT UP STILL HOLDING THE MODE BUTTON UNTIL YOU HEAR A BEEP.
UNPLUG UNIT  AND THEN PLUG IT BACK UP AND ONE OF THESE 2 STEPS WILL FIX YOUR PROBLEM   UNLESS THERE IS A MAJOR PROBLEM IN THE CONTROL BOARDS
Oct 13, 2007 | Sharp AFS60FX Air Conditioner
Heating & Cooling Logo
247 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
