Question about NetGear Computers & Internet
Limited or no conncetivity?
Ive got a netgear ethernet hub model EN 104tp. i cant seem to getthe internet to go thru it, when i plug the ethernet cable from the modem to the hub , then another cable for the hub to the computer it comes up with limited or no conncetivity?
  • 1,272 Answers
Seems to be issue with the switch. If you can get internet after bypassing the switch then it is for sure an issue with the switch. try connecting the cable to other ports of the switch.
If it still does not work then it is time for you to replace the switch.
Rate it,if it helps.
Posted on Jun 30, 2009
  • 560 Answers
The "limited access" message is an indicator that Windows has not been able to get an IP address by DHCP, usually an encryption related issue. I would recommend to use WPA, WPA2 encryption.
Remove all your wireless networks stored, re-add your own SSID(wireless network), make sure to type the correct encryption.
Get instant online Netgear router support at http://www.vtechsquad.com/netgear-router-support/ to fix any issue related with your Netgear router/wireless router problem.
Posted on Oct 12, 2012
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear RangeMax Dual Band Wireless-N...
My Ethernet lite will not come on on my modem, cannot get online thru this wireless router, tried reconnecting cables and power down the modem per set up instructions that came with the netgear router,...
if your modem has an ethernet connection the drivers should be on the disk provided by the internet provider
control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Nov 30, 2010 | NetGear WGR614 Wireless Router
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Ethernet Hub EN104 Hit and Miss.
    Are you sure you got a compatible modem? They are not all alike.
    Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
    How to connect netgear fs108 to cable modem
    leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
    Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
    With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
    Any doubts further ? please clarify with me.... I am ready to help you....
    May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
    I cannot connext my xbox360. internet light is not on on roiuter but i have an internet connection, how do i fix
    The internet light indicates that a connection is made from the Internet port on the router to a device. This device should be a DSL modem or Cable modem.
    The connections you plug the wires in a twisted pair Ethernet network into come in two flavors, DTE and DCE. There are 8 wires and two are used for transmission, two for reception with 4 unused.
    The physical connections are the same on either end, so this is confusing. There are two types of cables, a "straight through cable" which can be used to connect DCE to DTE (a DTE is a computer or X-Box or something that is the end of the line, while a DCE is a Commuications device, like a hub. A modem or hub or cable adapter is a DCE. You plug your computer (DTE) into a modem (DCE) with a straight through cable. To plug a hub to a hub, you need either a crossover cable or a "X" port on the hub.
    While many new devices are auto-sensing, the WGR614 is not, and they caution you that you may need a crossover cable, and to check the manual for the modem or cable device.
    A manual for your router can be found at http://kbserver.netgear.com/pdf/wgr614v6_ref_man_20Apr05.pdf but I don't know what kind of DSL modem or cable adapter or whatever you have so I can't guess further. I found the explanation for "why is my internet light off" with the suggestion that you might be plugging DCE to DCE.
    If you want to make your own crossover, it is not hard if you have the clamp for the RG-58 8 position connector.
    Pins 1 and 2 are TD + and minus, and 3 and 6 are RD plus and minus. For a crossover cable, you need to swap 1 with 3 and 2 with 6. See http://www.kryslix.com/nsfaq/Q.4.html
    Jan 10, 2010 | NetGear WGR614 Wireless Router
    How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
    Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
    Dec 05, 2009 | NetGear WGR614 Router
    Motorola Surfboard 4220 not working with my Netgear WGT624 router
    Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
    Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
    Hope this helps. Let me know if it does not work.
    Please rate.
    Mar 23, 2009 | Arris SURFboard SB4220 Modem
    No connection when installing WGT624 Netgear router
    Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
    Jan 09, 2009 | NetGear WGT624 Wireless Router
    Setting up netgear dg834gmodem router
    u will need to call netgear get your isp or ther dns server codes they will tell u it and u will enetr in the network adpoters properties area ok thx nick
    Mar 13, 2008 | NetGear DG834G Router
    Computers & Internet Logo
    1,403 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
