Memory Read/write error when I turn my laptop on.
It tells me to reseat the memory. I did that, but the laptop still won't boot.
  • 82 Answers
If you have more than one memory module installed, try removing one, then other.
If not, you must try with an equivalent module...
Always remove the battery and mains before removing memory modules and follow antistatic precautions...
Posted on Jun 29, 2009
Laptop beeps 7 times
Try link: http://blog.parts-people.com/2014/06/27/dell-inspiron-m501r-m5010-beep-codes-diagnostic-indicators-2/ How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jul 21, 2014 | Dell Inspiron M501r Laptop Computer (AMD...
Dell Inspiron N5010 4 beep error
This may help. The 4 beep code error in Dell Inspiron N5010 mean Memory read / write failure. Try draining the residual charge and check if you are able to boot. Here are the steps:
  • Disconnect any external peripherals (flash drives, printers, external hard drives) from the computer including the battery and AC Adapter.
  • Press and hold the power button for 20 seconds.
  • Reconnect the battery and the AC Adapter. Try to restart the computer and check.
Please make sure that the memory modules are firmly reseated and there is no dust accumulated on the memory slot on motherboard.
May 20, 2014 | Dell Inspiron Computers & Internet
I have a dell inspiron 1750 laptop... when i turn it on it say "Memory write\read failure at 0C034000, read 03EC00EC expecting 03E03EC To resolve issue, try to reseat the memory. Decreaing...
1. First thing to try (least expensive) is to REMOVE the memory stick or sticks and RESEAT them back into their respective slots. Boot up the laptop and check for results.
2. If this does NOT work, remove them again, clean the copper ends with CLEAN pencil eraser.
RESEAT them and check results.
3. Purchase replacement memory sticks/modules.
NOTE: Turn-off your laptop AND unplug A/C adapter. Be careful removing these modules. Touch each module at the corners.
Please advise of results.
Apr 04, 2011 | Dell Inspiron 1750 Laptop
Memory write/read failure at 000510784, read EA05E805 expecting EA05E805 . To resolve try to reseat memory.
Hello.
To reseat the memory modules, disconnect all cables and remove the battery. Flip the laptop and remove the memory cover (has one screw). Remove the module(s) on a slant. Reinsert in place. Replace the memory cover. Insert the battery. Connect the a/c adapter and power on.
If you receive the same error, replace the memory. Can be found on the Dell site.
Hope this helps.
Feb 27, 2011 | Dell Inspiron 1525 Notebook
At boot up my Dell Inspiron 8000 laptop gives a "Memory write/read failure" error message and will not continue booting. How do I solve this error and boot the laptop?
Check your memory, On the bottom of the computer is a small door to access the computer main memory. Check to see if it is not knocked loose - reseat it. and then it may be bad -and will need to replace it.
Nov 17, 2009 | Office Equipment & Supplies
I cant boot up my computer(memory address line failure)
This is clearly a problem with the memory. You can try two things:
1) Remove and reseat the memory sticks (with the unit unplugged)
2) Swap the boards around. Windows is not very tolerant of errors in the lower portion of memory. Swapping around the boards will change the relationship of physical memory addresses to virtual addresses. At the very least, the memory swap may help to determine which memory stick is defective.
Please keep us posted.
Dan
Aug 20, 2009 | Dell OptiPlex GX110 PC Desktop
Black screen saying to reseat memory
Theres no risk losing any data if you reset the memory.
If above doesnt work you could trying taking the memory out and cleanng the connection points with a soft cloth.
When placing the memory stick back in -making sure it sitting straight and securely on the board (memory shouldnt move if put in correctly) .
Try booting up the laptop now...good luck.
Jul 07, 2009 | Dell Inspiron 1525 Notebook
Dell inpiron 1535 laptop - memory write\read failure
memory write/read failure at 14020058,read ED22ED02 expecting ED02ED02
decreasing available memory
Apr 08, 2009 | Dell Inspiron 1525 Notebook
Memory write/read error on start up
Do not post your service tag on any forum, it is private data and needs to be protected (some turkey tried to get some stuff from Dell on a friend of mine's account using her tag she had posted)
If the system will post and boot, try flashing the BIOS to the current version. Then try each RAM module one at a time. Generally, only one module will fail at a time. SO take one out, boot to BIOS (SO it recognizes the RAM quantity change) then see if the system boots without error. If it does, then the module removed is likely bad. If the error still occurs, try the steps above with the other module. If errors occur with only 1 module, replace that one.
If errors occur with either module, you may have a motherboard issue. Or, very unlikely, 2 bad memory modules
Mar 23, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
Computers & Internet Logo
242 people viewed this question
David Payne
David Payne
