I have an American electric hot water heater. Model MI80R6DS13 240V 80 Gal S/N YB0849253. Recently, the relief valve blew and I had a big water mess. I have since repaired the water damage. Upon inspection of the unit, I found that the top thermostat was charred (physically burned), at the terminals that connect to the top heater coil. I guessed that was the problem and replaced that thermostat with the same part. I am trying to do this myself due to financial constraints, and my basic competence as an electrical engineer. When I re-connected power, I found that the temperature is still in a run-away situation. The unit heats to scalding hot even with both the top and bottom thermostat on the lowest setting. I have shut off the unit at the circuit breaker, pending advice what to do next. I can't afford to have more water damage in my home. The unit was installed in 2002. Any ideas?
  • 1 more comment
  • mffoley16 Jun 30, 2009
    The new thermostat I installed was a Camco #07863 240V Up DP Thermostat. This is exactly the same one that was on the original unit that was charred at some point near the overheating incident that caused the relief valve to blow.
    I can't find a Wattage rating for this part on-line.
    Your idea would make sense except for the fact that the new Thermostat does not seem to be working properly, right out of the box. It's hard to beleive that the terminals welded the very first time it was used, if it was the manufacturer's recommended part.
    Any other ideas?
    sounds plausible. I will check it this weekend when we are back at the house. If this is it, I will let you know. I will accept your solution since it seems plausible and I was looking for troubleshooting advice....
    MF
    Thanks for the troubleshooting idea! I will check it out.
  • 508 Answers
Unit maybe full of calcium turn off power drain open relief valve to drain remove bottom element if white crusty stuff thats calcium use coat hanger to pull out chunks then pour white vinegar let sit overnight it will dissolve chunks then completely rinse with hose!!!Calcium will short out bottom element and cause to overheat and burn out parts!!!Best of luck to you!!!!Let me know outcome!!!!
Posted on Jun 30, 2009
  • 221 Answers
OK. Logicaly thinking It can't be nothing else just thermostat (assuming it was connected correctly). First Make sure that the thermostat you'we just installed is capable to to withstand 4500W power. Or just get the bigger one, lets say the one which could withstand up to 6000W or so. The thing is, as your Heating element is rated 4,5KW so if thermostat is ratet the same, at the point of kick-on the contacts inside the thermostat might stick together (like welded) due to excessive current flow. On this occasion the thermostat is like switch and all the switches should be chosen to be able withstand up to 25 percent of rated wattage. So at this point get a bt more powerfull thermostat and you will definitely be sorted.
I heard tha kenmore heaters has exactly the same problem. So with time some of the ratings just needs to be adjusted as after couple of years all the manufacturers estimations seem not to work as smooth as expected.
Best of luck for you!
Gee
Posted on Jun 29, 2009
50 gal. kenmore elite hot water heater model#153.332640 installed 05/01/2011 in February 0f 2017 it started blowing water out of relief valve. temp at faucet 145degrees . rplcd gas contr valve/therm
If the water coming out is really hot, you probably have a faulty thermostat, which allows water to overheat. If water is warm or cold, you probably have defective temp/pressure relief valve.
Jan 12, 2018 | Water Water Heaters
Pressure relief valve intermittent noise
check your water pressure and then make sure it is not to high or all the problems you have had were not the answer. it is a pressure /temperature valve not just . temp.
Apr 06, 2014 | RHEEM 40 GAL ELEC Water Heater 6YR SC...
Relief valve buzzing noise
Add an extrol expansion tank to the piping. You can get one for about thirty dollars from the hardware store.
Apr 06, 2014 | Rheem 82V40-2 Fury Electric Residential...
No hot water comes into the house
1) Copy following link:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#no
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Low-hot-water-pressure.html
2) One pipe on top of heater is warm??? >> breaker is ON >>> this indicates that electric water heater has hot water.
When you opened the TP valve, did hot water come out???
3) Feb 2013 >> add a comment.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 24, 2013 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Atwood Hot Water heater wont' shut off
sounds like defective thermostat/gas valve
Aug 05, 2012 | RTO Atwood Water Heater - 6 Gal LP
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Water heater fires and runs for 2 or 3 minutes and then cuts off.It tries to refire 2 or three times but wont .Red light inside comes on as if it is out of gas.I changed the T-stat and ECO and it still...
First of all, lets see if water is hot already by releasing pressure relief valve slightly and seeing if water is already hot.BE CAREFUL NOT TO SCALD YOURSELF! Shut water pressure off, first, but be aware it will still be under pressure at first.. Just hold a cup, or something under it and open it up slightly, or at least feel pressure relief valve to see if it feels warm/hot to touch. May just be by-pass not set properly in back of water heater. Let me know if hot from pressure relief at outside on heater.
Dec 23, 2010 | RTO Atwood Water Heater - 6 Gal LP
Water just gets luke warm on propane or electric. has electronic ignition, do i need circuit board? Atwood 6 gal. tank
Run it on propane and let water heater go through a heating cycle, and when it shuts off, CAREFULLY , pull the lever on the pressure relief valve slightly and see how hot the water feels there. If it's hot there, then it's more than likely a problem with your by-pass valve(s) at the back of the water heater. Either in the wrong position, or faulty, and allowing hot and cold to mix. If in doubt which one it may be, you may be able to remove by-pass set-up completely, depending on what system you have. What the ultimate goal is would be to attach your incoming cold line directly to bottom fitting of water heater, and outgoing hot line, to the top. Not unusual in some systems for one of the shut-offs in between the 2 lines to stay partially open, and allow cold to mix with hot, thus -warm only. If it's not hot at pressure relief valve, then I suspect a faulty thermostat, but that would mean they both (hydro and gas) would have to be faulty which is unlikely.
Jun 17, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have a jackson Low Temp single door model.. I
you may need to clean out your hot water heater depending on how old it is and yes 80 gal should be more than big enough adj. thermostat to the next level
Jun 09, 2010 | Jackson 25 in. Conserver XL Free-standing...
Heating element cycling on and off fairly often
Yes, unfortunelty elextric water heaters do cycle a lot. They are a little bit different from gas water heaters, in the fact that they run differently and seem to run out of hot water faster, then gas water heaters. Just make sure, that the thermostat is set at 120 F. The thermostat will be behind a panel, and under the electrical wire connections. You will have to use a flathead screw driver, to change the temp. settings, if they need changing. Also, make sure that once a year, that you flip the Pressure relief valve to equalize the pressure and to drain at least 2 gallons of water out of the tank.
Jan 20, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
