Question about Proview PL913S 19" Flat Panel LCD Monitor
Extension cable I added an extension cable to my monitor and am now having a couple problems.  The  first one is the screen seems fuzzy.  I tried making adjustments with no luck.  The second problem is that the screen size shrinks to about 3/4 size when it sits for any length of time.  I can reset it to full size but it happens again when it sits Could this all be caused by an inferior cable?
  • 593 Answers
By all means yes. Longer VGA cables need superior shielding, and signal degrades over distance. So either get a better extension cable or move your CPU closer to the monitor and run extensions for your keyboard and mouse.
Posted on Apr 05, 2008
I connected an external monitor to a lap top. The screen on the monitor is bouncing making all the print fuzzy and difficult to read.
Have you tried the same connection with another monitor? That will tell you if the cable or monitor is the problem. If the same thing happens with another monitor then its the computer input or system drivers.
Dec 31, 2013 | Computers & Internet
My HP w2228h LCD monitor has all of a sudden gone
go to bios and see whether the lines are there or the screen is fuzzy or not
if it is then the monitor has gone bad and if not update the bios
download bios update frm
Mar 18, 2010 | HP Computers & Internet
Acer 1716 17 inch LCD monitor, screen fuzzy w/white lines at rt
Common problem.
There are 8 small VRAM BGA chips.
1 or 2 of them needs REFLOW.
Basically board service.
Dec 16, 2008 | Acer AL1716 17" LCD Monitor
My t.v screen is fuzzy and the picture is showing double on one side and it at times seem s streched
The stretching might be due to having the wrong aspect size on your tv. Look on your remote and see if you have a button that says "Aspect" or it could say "ratio" or something to that effect. You can cycle through the different screen sizes to make it not appear to be stretched. As far as your picture being fuzzy, if you are using a standard antenna that may be the cause. If you are using cable, I would contact the cable company and have someone come out and check your signal strength, and possible inquire if you need a cable booster added. If you are running cable through a cable box and are running it straight coaxle then I would recommend trying a different hookup method, e.g Red, white yellow cables, or S-video or even hdmi, whichever your cable/satellite box and tv allows.
Dec 15, 2008 | Panasonic TH-37PA20U/P 37 in. Plasma...
I have a Westinghouse LCM-22W2 LCD monitor. I believe my power board is bad. I want to either replace the power board or bad capcitors, if I can find them. I do not know how to take off the back cover,...
Have you gone through the user's guide? There are some sleep settings and automatic adjustments that this monitor makes, and other changes that users have inadvertently triggered that seem to be causing quite a bit of confusion these days. Make sure you haven't overlooked the Troubleshooting steps outlined there:
No Power
• Make sure the AC cord is plugged into the back of the LCD monitor.
• Make sure the AC power cord is securely connected to an AC outlet.
• Plug another electrical device (like a radio) to the power outlet to verify that the
outlet is supplying the proper voltage.
No Screen Image
• Make sure monitor is turned on.
• Make sure the video cable is securely connected to both the monitor and PC or
Audio/Video apparatus.
• Make sure you have selected the correct video input source
• Adjust the brightness and contrast levels.
“Out Of Range”
• Restart your computer and adjust your desktop resolution and refresh rate to 1680 x
1050 at 60 Hz.
Fuzzy Image
• Set desktop resolution on your PC to 1680 x 1050 at 60 Hz.
• Adjust Phase/Sharpness setting on the monitor
Cannot find 1680 x 1050 under screen resolution on my Display Properties
• You may need to download and install the latest video card driver for your PC.
Listed below are websites for major video card manufacturers:
Image Too Bright or Too Dark
• Adjust the brightness and contrast levels under the OSD menu.
• Perform Auto Adjust.
Distorted Image
• Reset the LCD monitor by performing the “Reset” function using the OSD.
• Remove extra accessories (such as a VGA extension cord).
Image is Not Centered (size is not scaled correctly)
• Adjust the horizontal and/or vertical position using the OSD.
• Check image size setting.
You can see an online version here:
I do not know how to remove the cover from that monitor. Here is a link to Westinghouse customer service technical support: or
Our service and support team is available:
Monday through Saturday
9 AM - 9 PM Eastern Time
1 (866) 287-5555
I hope this helps to resolve your issue.
Dec 07, 2008 | Westinghouse 22" Widescreen LCD Flat Panel...
Benq screen resolution auto adjust seems to auto adjust wrongly
I would recommend you to bring it back and get a new one, if its till under warranty. You cannot fix the problem on the panel buttons it looks something to do with the components in the circuit bord.
Nov 19, 2008 | BenQ FP731 17" LCD Monitor
Fuzzy screen, not a flat screen.
TFT Monitor fuzzy display problems are almost always caused by one (or more) or the following issues:
  • Wrong display resolution. As mentioned elsewhere, TFT Monitors must be configured to use their Native Resolution in the PCs display settings. Failing to do this will always cause the display to be fuzzy or blurred - or to have jagged edges on diagonal lines and a 'lumpy' looking display.
  • Poor adjustment. If the display resolution is correct, then the monitor has to be correctly adjusted to get the best picture quality. This is usually only an issue with analogue monitors. If the digital (DVI) input is used, then further adjustment of the monitor should not be required. Initially, the monitors "Auto-Adjustment" can be used to try and improve the display quality. This is best used with a program producing a test pattern of vertical lines, with a single pixel white border showing the exact edge of the screen. Given this, most monitors will auto-adjust perfectly well. If the display is still not perfect, a very slight manual adjustment will usually achieve the expected quality.
  • Poor quality cables. Monitors are susceptible to signal degradation from either poor quality or excessively long signal cables. Also, joining or extending cables is likely to cause ghosting effects on the display, usually seen as light and dark vertical lines.
  • Faulty graphics cards or other component. In most cases upgrading the driver ill resolve this issue. If none of the above suggestions work then get me the brand and model number of your graphicscard and we will update the driver.
Nov 16, 2008 | Kogi L9CH 19" Flat Panel LCD Monitor
SyncMaster 2253 BW Samsung
Have try open your monitor on screen display (OSD) and used the auto adjust settings.
Oct 13, 2008 | Samsung SyncMaster 2253BW LCD Monitor
I have posted this response to similar problems.
Your display being fuzzy as you described is indicative of either:
a. weak picture tube; or
b. component failure or deterioration.
Even if it were a weak picture tube or deterioration, it is still possible to "squeeze" a few more usable time out of the monitor. You simply have to adjust the focus control. Normally, this is accessible from the rear of the electronic circuit board and is a part of the Flyback transformer (FBT). Below is an image of a sample FBT. Pls notice the two (2) protrusions, one of them is marked as Screen and the other as the Focus. You need to adjust the focus till it satisfies your visual requirement or preference.
A word of caution. This procedure is not recommended if you have no TV/Monitor repair experience. It is not a fix. It is as earlier stated, squeezing in just a few more usable time. The unit would have to be adjusted "live" with the cover off. You need to be familiar with electronic components, tools and circuitry as well as working with powered devices and extremely High Voltage. The monitor may have to be operated with insulated support since the back cover will not be attached. Additionally, you may need to use a mirror to check if you adjusted it as you want it.
As you try to adjust it with an insulated screwdriver, you will notice that there is mid point where the focus will just be about right. You may have to adjust a couple of times to get the setting as you want it.
Should you feel uncomfortable doing this, perhaps you may need to seek the assistance of a qualified TV/Monitor technician.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jun 26, 2008 | NetTV DTV 34X 34 in.CRT Conventional...
Open Questions:
See all Proview PL913S 19" Flat Panel LCD Monitor Questions
Proview PL913S 19" Flat Panel LCD Monitor Logo
44 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
